Connect ardunio due to MKR shields
Hello,
I am new to Arduino. I am trying to connect the Arduino due board to an MKR GPS shield and MEM shield. I want to know if it is possible to do it with jumper wires. I do not find many shields for the due board so I have no solution but to get some shields from the MKR series.
Thank you for your advice and help.
If you want to connect shields with wires - so you do not need a shields, you can use just modules
Sure. Initially, I just want to use the shield so that I can forget the compatibility when choosing components and it is not the case. But I already got the components now so I am trying not to waste them. Do you mean it is possible to do it with wires?
MKR and DUE are not the same board, and libraries written for MKR shields might not work out of the box for DUE. Try it
Now I just find it difficult to connect the pins. Is there anyone who used to try the pin connection between due and MKR shields?
