Connect buzzer to temperature sensor arduino
I have two codes, one for temperature and humidity and another for a buzzer ; both work fine, but how can I combine them so that when the temperature rises, the buzzer activates?
i use :
esp8266
DHT11
buzzer passive and active
Read this
https://forum.arduino.cc/t/beginners-combining-two-codes-doesnt-work/599945
and this
Welcome
so that we can help you better, I suggest that, using the </> tags, post both codes that work and your attempt to put the codes together, even if it doesn't work.
Please explain. What is a "buzzer sensor"? Unless, it will be obvious from the code that you post.
its a passive and active buzzer
this is buzzer code on arduino :
#define CAYENNE_DEBUG // Uncomment to show debug messages
#define CAYENNE_PRINT Serial // Comment this out to disable prints and save space
#include <CayenneMQTTESP8266.h>
// WiFi network info.
char ssid[] = "---";
char wifiPassword[] = "---";
// Cayenne authentication info. This should be obtained from the Cayenne Dashboard.
char username[] = "---";
char password[] = "---";
char clientID[] = "---";
const unsigned char Passive_buzzer = 2;
const unsigned char Active_buzzer = 14;
const unsigned char built_in_led = 16;
void setup () {
pinMode (Passive_buzzer,OUTPUT) ;
pinMode (Active_buzzer,OUTPUT) ;
pinMode (built_in_led,OUTPUT) ;
void loop () {
digitalWrite(built_in_led,LOW) ; //Turn on the built in led
digitalWrite(Active_buzzer,HIGH) ; //Turn on active buzzer
delay (1000);
digitalWrite(built_in_led,HIGH) ; //Turn off the built in led
digitalWrite(Active_buzzer,LOW) ; //Turn off active buzzer
delay (1000);
tone(Passive_buzzer, 523) ; //DO note 523 Hz
delay (1000);
tone(Passive_buzzer, 587) ; //RE note ...
delay (1000);
tone(Passive_buzzer, 659) ; //MI note ...
delay (1000);
tone(Passive_buzzer, 783) ; //FA note ...
delay (1000);
tone(Passive_buzzer, 880) ; //SOL note ...
delay (1000);
tone(Passive_buzzer, 987) ; //LA note ...
delay (1000);
tone(Passive_buzzer, 1046) ; // SI note ...
delay (1000);
noTone(Passive_buzzer) ; //Turn off the pin attached to the tone()
and this is DHT11 sensor code:
Cayenne DHT11 Sensor Project
#define DHTPIN 0 // D3
// Uncomment whatever type you're using! In this project we used DHT11
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
#include <DHT.h>
DHT dht(DHTPIN, DHTTYPE);
//Variables for DHT11 values
float h;
float t;
bool humidity = false;
bool Temperature = false;
Serial.print("Setup");
Cayenne.begin(username, password, clientID, ssid, wifiPassword);
humidity = false;
//Run Cayenne Functions
Cayenne.loop();
CAYENNE_OUT(V0){
//Serial.println("humidity");
//Check if read failed and try until success
do {
//Read humidity (percent)
h = dht.readHumidity();
} while (isnan(h));
Serial.print("humidity: ");
Serial.println(h);
Serial.print(" %\t");
//Set Humidity to true so we know when to sleep
humidity = true;
//Write to Cayenne Dashboard`
Cayenne.virtualWrite(V0, h);
CAYENNE_OUT(V1){
//Serial.println("temperature");
do {
//Read temperature as Celsius
t = dht.readTemperature();
} while (isnan(t));
Serial.print("temperature: ");
Serial.println(t);
Serial.println(" *C");
//Set Temperature to true so we know when to sleep
//Temperature = true;
Cayenne.virtualWrite(V1, t);
i need to put if else condition on buzzer code
I want to the buzzer to alarm when temp hits a min and a max.
It doesn't appear to be reading the temp sensor. all it does is alarm..
this is buzzer code\ :point_down:
char ssid[] = "----";
char username[] = "--";
char clientID[] = "--";
void setup () {
void loop () {
delay (1000);
delay (1000);
delay (1000);
delay (1000);
delay (1000);
delay (1000);
delay (1000);
delay (1000);
delay (1000);
and this is DHT11 sensor code :point_down:
#include <DHT.h>
char ssid[] = "--";
char wifiPassword[] = "--";
float h;
float t;
  humidity = false;
  Cayenne.loop();
CAYENNE_OUT(V0){
  do {
  } while  (isnan(h));
  Serial.println(h);
  humidity = true;
CAYENNE_OUT(V1){
  do {
  } while  (isnan(t));
  Serial.println(t);
Then make an attempt and post it in a new message. Here is the reference for the 'if' statement:
https://www.arduino.cc/reference/en/language/structure/control-structure/if/
why not something as simple as this
#include <DHT.h>
DHT dht (DHTPIN, DHTTYPE);
const float TempMin = 20.0;
const float TempMax = 24.0;
void setup ()
void loop ()
    float t = dht.readTemperature ();
    if (t < TempMin || TempMax < t)
        digitalWrite(Active_buzzer, HIGH); // on
        digitalWrite(Active_buzzer, LOW); // off
try this code:
#include <DHT.h>
char ssid[] = "--";
float h;
float t;
float tOld;                 // Save initial or old read temp.
  pinMode (Passive_buzzer, OUTPUT) ;
  pinMode (Active_buzzer, OUTPUT) ;
  pinMode (built_in_led, OUTPUT) ;
  humidity = false;
  tOld = dht.readTemperature();
  Cayenne.loop();
CAYENNE_OUT(V0) {
  do {
  } while  (isnan(h));
  Serial.println(h);
  humidity = true;
CAYENNE_OUT(V1) {
  do {
    if ( tOld < t)      // If new ra is high then old call buzzer
      sound();          // Sound buzzer
    tOld = t;           // Save new read
  } while  (isnan(t));
  Serial.println(t);
void sound() {
  digitalWrite(built_in_led, LOW) ; //Turn on the built in led
  digitalWrite(Active_buzzer, HIGH) ; //Turn on active buzzer
  delay (1000);
  digitalWrite(built_in_led, HIGH) ; //Turn off the built in led
  digitalWrite(Active_buzzer, LOW) ; //Turn off active buzzer
  delay (1000);
  delay (1000);
  delay (1000);
  delay (1000);
  delay (1000);
  delay (1000);
  delay (1000);
  delay (1000);
