Connect Colour OLED to pro mini (PLEASE HELP!!)
I need help connecting my arduino pro mini to a colour oled please.
The code is an example for the oled display, it has worked on my arduino UNO, so I don't know why it isn't on the pro mini
  This is a example sketch demonstrating the graphics
  capabilities of the SSD1331 library  for the 0.96"
  16-bit Color OLED with SSD1331 driver chip
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/products/684
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1331.h>
#include <SPI.h>
// You can use any (4 or) 5 pins
#define sclk 6//scl
#define mosi 5//sda
#define cs   4
#define rst  3//res
#define dc   2
// Color definitions
#define BLACK           0x0000
#define BLUE            0x001F
#define RED             0xF800
#define GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
Adafruit_SSD1331 display = Adafruit_SSD1331(cs, dc, rst);
float p = 3.1415926;
void setup(void) {
  Serial.print("hello!");
  display.begin();
  Serial.println("init");
  uint16_t time = millis();
  display.fillScreen(BLACK);
  time = millis() - time;
  Serial.println(time, DEC);
  lcdTestPattern();
  display.setCursor(0,0);
  display.print("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa");
  tftPrintTest();
  delay(2000);
  display.drawPixel(display.width()/2, display.height()/2, GREEN);
  testlines(YELLOW);
  testfastlines(RED, BLUE);
  testdrawrects(GREEN);
  testfillrects(YELLOW, MAGENTA);
  testfillcircles(10, BLUE);
  testdrawcircles(10, WHITE);
  testroundrects();
  testtriangles();
  Serial.println("done");
void testlines(uint16_t color) {
   for (int16_t x=0; x < display.width()-1; x+=6) {
     display.drawLine(0, 0, x, display.height()-1, color);
   for (int16_t y=0; y < display.height()-1; y+=6) {
     display.drawLine(0, 0, display.width()-1, y, color);
     display.drawLine(display.width()-1, 0, x, display.height()-1, color);
     display.drawLine(display.width()-1, 0, 0, y, color);
   // To avoid ESP8266 watchdog timer resets when not using the hardware SPI pins
   delay(0);
     display.drawLine(0, display.height()-1, x, 0, color);
     display.drawLine(0, display.height()-1, display.width()-1, y, color);
     display.drawLine(display.width()-1, display.height()-1, x, 0, color);
     display.drawLine(display.width()-1, display.height()-1, 0, y, color);
void testdrawtext(char *text, uint16_t color) {
  display.setTextSize(1);
  display.setTextColor(WHITE);
  for (uint8_t i=0; i < 168; i++) {
    if (i == '\n') continue;
    display.write(i);
    if ((i > 0) && (i % 21 == 0))
      display.println();
void testfastlines(uint16_t color1, uint16_t color2) {
   for (int16_t y=0; y < display.height()-1; y+=5) {
     display.drawFastHLine(0, y, display.width()-1, color1);
   for (int16_t x=0; x < display.width()-1; x+=5) {
     display.drawFastVLine(x, 0, display.height()-1, color2);
void testdrawrects(uint16_t color) {
 for (int16_t x=0; x < display.height()-1; x+=6) {
   display.drawRect((display.width()-1)/2 -x/2, (display.height()-1)/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
 for (int16_t x=display.height()-1; x > 6; x-=6) {
   display.fillRect((display.width()-1)/2 -x/2, (display.height()-1)/2 -x/2 , x, x, color1);
   display.drawRect((display.width()-1)/2 -x/2, (display.height()-1)/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
  for (uint8_t x=radius; x < display.width()-1; x+=radius*2) {
    for (uint8_t y=radius; y < display.height()-1; y+=radius*2) {
      display.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
  for (int16_t x=0; x < display.width()-1+radius; x+=radius*2) {
    for (int16_t y=0; y < display.height()-1+radius; y+=radius*2) {
      display.drawCircle(x, y, radius, color);
void testtriangles() {
  int color = 0xF800;
  int t;
  int w = display.width()/2;
  int x = display.height();
  int y = 0;
  int z = display.width();
  for(t = 0 ; t <= 15; t+=1) {
    display.drawTriangle(w, y, y, x, z, x, color);
    x-=4;
    y+=4;
    z-=4;
    color+=100;
void testroundrects() {
  int color = 100;
  int i;
  int t;
  for(t = 0 ; t <= 4; t+=1) {
    int x = 0;
    int y = 0;
    int w = display.width();
    int h = display.height();
    for(i = 0 ; i <= 8; i+=1) {
      display.drawRoundRect(x, y, w, h, 5, color);
      x+=2;
      y+=3;
      w-=4;
      h-=6;
      color+=1100;
    color+=100;
void tftPrintTest() {
  display.setCursor(0, 5);
  display.setTextColor(RED);
  display.println("Hello World!");
  display.setTextColor(YELLOW, GREEN);
  display.setTextSize(2);
  display.print("Hello Wo");
  display.setTextColor(BLUE);
  display.setTextSize(3);
  display.print(1234.567);
  delay(1500);
  display.setTextSize(0);
  display.setTextColor(GREEN);
  display.print(p, 5);
  display.println(" Want pi?");
  display.print(8675309, HEX); // print 8,675,309 out in HEX!
  display.print(" Print HEX");
  display.println("Sketch has been");
  display.println("running for: ");
  display.setTextColor(MAGENTA);
  display.print(millis() / 1000);
  display.print(" seconds.");
void mediabuttons() {
 // play
  display.fillRoundRect(25, 10, 78, 60, 8, WHITE);
  display.fillTriangle(42, 20, 42, 60, 90, 40, RED);
  // pause
  display.fillRoundRect(25, 90, 78, 60, 8, WHITE);
  display.fillRoundRect(39, 98, 20, 45, 5, GREEN);
  display.fillRoundRect(69, 98, 20, 45, 5, GREEN);
  // play color
  display.fillTriangle(42, 20, 42, 60, 90, 40, BLUE);
  delay(50);
  // pause color
  display.fillRoundRect(39, 98, 20, 45, 5, RED);
  display.fillRoundRect(69, 98, 20, 45, 5, RED);
  // play color
  display.fillTriangle(42, 20, 42, 60, 90, 40, GREEN);
    @brief  Renders a simple test pattern on the LCD
void lcdTestPattern(void)
  uint8_t w,h;
  display.setAddrWindow(0, 0, 96, 64);
  for(h=0; h<64; h++)
    for(w=0; w<96; w++)
      if(w>83){display.writePixel(WHITE);}
      else if(w>71){display.writePixel(BLUE);}
      else if(w>59){display.writePixel(GREEN);}
      else if(w>47){display.writePixel(CYAN);}
      else if(w>35){display.writePixel(RED);}
      else if(w>23){display.writePixel(MAGENTA);}
      else if(w>11){display.writePixel(YELLOW);}
      else {display.writePixel(BLACK);}
  display.endWrite();
It would not work on the Uno unless you use the hardware SPI pins for MOSI, SCK.
If you want to use random pins, use the Software constructor:
Adafruit_SSD1331 display = Adafruit_SSD1331(cs, dc, mosi, sck, rst);
David.
Is this a 3.3 V Pro Mini?
You appear to have 5 V connected to the "RAW" pin. :astonished:
Suggest you do not post .pdf files. :roll_eyes:
Good work using "code" tags. :grinning:
It is a 5v version :slight_smile:
Then connect your 5 V supply to the "5V" terminal.
Did you set jumpers for 5V? Did you connect VCC pins to the 5V rail?
Did the OLED work with the software constructor?
Did you try connecting MOSI to D10, SCK to D13 ? Then using the hardware constructor?
David.
