When using two separate power supplies (for servos and logic), I understand that there must be a common ground connection between both circuits for the servos to function properly. In doing so, I have seen dozens of tutorials where people use two separate switches to enable/disable power to each circuit separately. Wouldn't it be possible to use a single SPST switch to (dis)connect the common ground from each circuit? See ASCII art below for diagram. This seems like it would work, and eliminate a switch from the design. Are there other issues with doing this that I may be missing?
???? GND ????
?9v????????????6v?
?+ ?SPST? ?+
? GND?????????
?ARDUINO ? ?SERVO?
SIGNAL
