Connect e-piano with arduino, Issue with midi connection.
Hey everyone,
first of all, sorry for posting here, but somehow I cannot post in the sub “general electronics”. If a mod is seeing this, please feel free to move this topic.
for a bigger project I am currently trying to connect my e-piano (Korg SP 100) to my arduino (Uno) with the help of a self made midi input circuit. I am following this instruction Notes and Volts: Midi for the Arduino - Build a Midi Input Circuit. The code can be found here Notes and Volts: MIDI for the Arduino - Arduino MIDI Library Input Test.
So far I set up the circuit and got the program code running on the Arduino. But somehow when I connect my piano with the circuit and play a note nothing happens. Either way the circuit is wrong or a component is broken. So i want to check every component, starting with the midi output of my piano. Question is, how can I check it if its working? Tried to use a voltmeter, but I read, that the interval of the current is too short to be measured. Another idea was to set up a small circuit with an LED and a 220 ohm resistor to connect the pin 4 and 5 of the midi output and see if I get a light signals that way. I tried and didnt get any, so either the midi is really broken or I used the wrong methods of testing.
Anyone has any ideas, what else I could do or how I could test the midi output of my piano? Buying a usb-midi cable is of course an option, but will take one week to be delivered. So maybe the is a faster solution.
Greetings :slight_smile:
In my opinion those links are not good. You should dig out the wanted information and present it here. The same for the code.
I don't spend time ton archeologic excursions to find things. Time can be used in a better way.
True. Here is a picture of the circuit:
And thats the code, which is used:
#include <MIDI.h>  // Add Midi Library
#define LED 13    // Arduino Board LED is on Pin 13
//Create an instance of the library with default name, serial port and settings
MIDI_CREATE_DEFAULT_INSTANCE();
  pinMode (LED, OUTPUT); // Set Arduino board pin 13 to output
  MIDI.begin(MIDI_CHANNEL_OMNI); // Initialize the Midi Library.
  // OMNI sets it to listen to all channels.. MIDI.begin(2) would set it
  // to respond to notes on channel 2 only.
  MIDI.setHandleNoteOn(MyHandleNoteOn); // This is important!! This command
  // tells the Midi Library which function you want to call when a NOTE ON command
  // is received. In this case it's "MyHandleNoteOn".
  MIDI.setHandleNoteOff(MyHandleNoteOff); // This command tells the Midi Library
  // to call "MyHandleNoteOff" when a NOTE OFF command is received.
void loop() { // Main loop
  MIDI.read(); // Continuously check if Midi data has been received.
// MyHandleNoteON is the function that will be called by the Midi Library
// when a MIDI NOTE ON message is received.
// It will be passed bytes for Channel, Pitch, and Velocity
void MyHandleNoteOn(byte channel, byte pitch, byte velocity) {
  digitalWrite(LED,HIGH);  //Turn LED on
// MyHandleNoteOFF is the function that will be called by the Midi Library
// when a MIDI NOTE OFF message is received.
// * A NOTE ON message with Velocity = 0 will be treated as a NOTE OFF message *
void MyHandleNoteOff(byte channel, byte pitch, byte velocity) {
  digitalWrite(LED,LOW);  //Turn LED off
Though it might not be relevant because it has worked for other people with the same code.
Well done! Perfect!
Check the pin numbers used in that 5 pin DIN connector. One of the connections needs to be earth, ground, to make a circuit. The level produced needs to be higher then some 2 volts to trigger the opto copler.
Check the baud rate settings in the sending device. Does MIDI lib set the baud rate for the receiving code? I see nothing like "Serial.begin(baud_rate)".
Railroader:
You should never connect the MIDI input connector to ground/earth. MIDI uses a current loop, not a voltage referenced to ground. MIDI devices should be galvanically isolated to prevent ground loops and many other ground-related issues, that's the whole point of using an opto-coupler in the first place.
Railroader:
Calling MIDI.begin(...) does that for you.
I suspect a hardware issue. Check the DIN pin numbers, the order depends on which end of the connector you're looking at, and whether you're using male or female jacks.
Pieter
PieterP:
You should never connect the MIDI input connector to ground/earth. MIDI uses a current loop, not a voltage referenced to ground. MIDI devices should be galvanically isolated to prevent ground loops and many other ground-related issues, that's the whole point of using an opto-coupler in the first place.Calling MIDI.begin(...) does that for you.
Pieter
No, no, no connection of grounds. I just wanted You to check, in this case that current + and current - are on pin 4 and 5 in the Din contact. Look into the DIN plug! As I remember You can read pin numbers in them! Light and magnifier... Watch the polarity, 4 and 5, or 5 and 4, if You understand.
Okey. Does the MIDI library set the same baud rate as the sending device?
I double-checked the position of the DIN contacts. However, somehow the problem solved itself magically. I could get the same parts again and build the same circuit and somehow this one was working. Then I replaced the new parts with the old parts and it was still working. So in the end I don't know what the issue was. Yesterday it didn't work to build the circuit three times again but today it works.
Well, thanks for your ideas, I am not that much in electronics yet, but your recommendations are a good way for further readings.
Nice it's working now!
Maybe a loose little flake of metal, or a strain of wire, made a short ciruit somewhere.
