Connect esp32 to Wifi
I am trying to connect my esp32 to my wifi connection but it keeps giving that it is trying to connect and it didnt connect,
The internet connection that I have very strong and the router is beside me.
I tried so many solution from google but it didnt work
any suggestion please?
#include <Arduino.h>
#include <WiFi.h>
#include <PubSubClient.h>
// WiFi
const char *ssid = "*****"; // Enter your WiFi name
const char *password = "******";  // Enter WiFi password
// MQTT Broker
const char *mqtt_broker = "broker.emqx.io";
const char *topic = "esp32/test";
const char *mqtt_username = "emqx";
const char *mqtt_password = "public";
const int mqtt_port = 1883;
WiFiClient espClient;
PubSubClient client(espClient);
 // Set software serial baud to 115200;
 // connecting to a WiFi network
 WiFi.begin(ssid, password);
     Serial.println("Connecting to WiFi..");
 Serial.println("Connected to the WiFi network");
 //connecting to a mqtt broker
 client.setServer(mqtt_broker, mqtt_port);
 client.setCallback(callback);
 while (!client.connected()) {
     String client_id = "esp32-client-";
     client_id += String(WiFi.macAddress());
     Serial.printf("The client %s connects to the public mqtt broker\n", client_id.c_str());
     if (client.connect(client_id.c_str(), mqtt_username, mqtt_password)) {
         Serial.println("Public emqx mqtt broker connected");
         Serial.print("failed with state ");
         Serial.print(client.state());
         delay(2000);
 // publish and subscribe
 client.publish(topic, "Hi EMQX I'm ESP32 ^^");
 client.subscribe(topic);
void callback(char *topic, byte *payload, unsigned int length) {
 Serial.print("Message arrived in topic: ");
 Serial.println(topic);
 Serial.print("Message:");
 for (int i = 0; i < length; i++) {
     Serial.print((char) payload[i]);
 Serial.println("-----------------------");
 client.loop();
Presumably your actual sketch has the correct SSID and password
Did you try wifiscan ?
Sure I put them correctly and I tried to connect it to different connections but same problem
Yes and I got my wifi connection name in the scanning
I am trying since two days and I waste much time but unfortunately same problem, I will get insane!!!
OK now try this
#include "WiFi.h"
const char* ssid = "yourNetworkName"; //choose your wireless ssid
const char* password =  "yourNetworkPass"; //put your wireless password here.
  // Print local IP address and start web server
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP()); //show ip address when connected on serial monitor.
void loop() {}
I do the thing this way.
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
@ZX80 I tried, I got the same
@Idahowalker I got the following error:
Compilation error: 'WiFiEvent' was not declared in this scope
Do you know how to solve this error please?
Put a / in front of the offending words.
like this
  int TryCount = 0;
    TryCount++;
    WiFi.disconnect();
    vTaskDelay( 4000 );
      ESP.restart();
  ////////////////WiFi.onEvent( WiFiEvent );
I got nothing in the serial monitor
#include "WiFi.h"
const char *SSID = "****"; // Enter your WiFi name
const char *PASSWORD = "****";  // Enter WiFi passwordvoid connectToWiFi()
  int TryCount = 0;
    TryCount++;
    WiFi.disconnect();
    vTaskDelay( 4000 );
      ESP.restart();
 connectToWiFi();
void loop() {}
The serial prints you put in the code did not work? Oh, wait you did not put serial prints to try to troubleshoot your issue. I guess I'll write some debugging code for you. I'll post it as soon as I've written the code. Wait for it.
I found this code @Idahowalker
and I got output:
connect to wifi
1
What does that mean? it didnt count more?
#include <WiFi.h>
#define WIFI_NETWORK "***"
#define WIFI_PASSWORD "***"
#define WIFI_TIMEOUT_MS 10000
void WiFiEvent(WiFiEvent_t event)
   Serial.println( "[WiFi-event] event: " + event );
  switch (event) {
        case SYSTEM_EVENT_WIFI_READY:
          Serial.println("WiFi interface ready");
        case SYSTEM_EVENT_SCAN_DONE:
          Serial.println("Completed scan for access points");
        case SYSTEM_EVENT_STA_START:
          Serial.println("WiFi client started");
        case SYSTEM_EVENT_STA_STOP:
          Serial.println("WiFi clients stopped");
    case SYSTEM_EVENT_STA_CONNECTED:
      Serial.println("Connected to access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      Serial.println("Disconnected from WiFi access point");
        case SYSTEM_EVENT_STA_AUTHMODE_CHANGE:
          Serial.println("Authentication mode of access point has changed");
        case SYSTEM_EVENT_STA_GOT_IP:
          Serial.println("Obtained IP address: " + WiFi.localIP() );
        case SYSTEM_EVENT_STA_LOST_IP:
          Serial.println("Lost IP address and IP address is reset to 0");
          //      vTaskDelay( 5000 );
          //      ESP.restart();
        case SYSTEM_EVENT_STA_WPS_ER_SUCCESS:
          Serial.println("WiFi Protected Setup (WPS): succeeded in enrollee mode");
        case SYSTEM_EVENT_STA_WPS_ER_FAILED:
          Serial.println("WiFi Protected Setup (WPS): failed in enrollee mode");
          //      ESP.restart();
        case SYSTEM_EVENT_STA_WPS_ER_TIMEOUT:
          Serial.println("WiFi Protected Setup (WPS): timeout in enrollee mode");
        case SYSTEM_EVENT_STA_WPS_ER_PIN:
          Serial.println("WiFi Protected Setup (WPS): pin code in enrollee mode");
        case SYSTEM_EVENT_AP_START:
          Serial.println("WiFi access point started");
        case SYSTEM_EVENT_AP_STOP:
          Serial.println("WiFi access point  stopped");
          //      WiFi.mode( WIFI_OFF);
          //      esp_sleep_enable_timer_wakeup( 1000000 * 2 ); // 1 second times how many seconds wanted
          //      esp_deep_sleep_start();
        case SYSTEM_EVENT_AP_STACONNECTED:
          Serial.println("Client connected");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      Serial.println("WiFi client disconnected");
        case SYSTEM_EVENT_AP_STAIPASSIGNED:
          Serial.println("Assigned IP address to client");
        case SYSTEM_EVENT_AP_PROBEREQRECVED:
          Serial.println("Received probe request");
        case SYSTEM_EVENT_GOT_IP6:
          Serial.println("IPv6 is preferred");
        case SYSTEM_EVENT_ETH_GOT_IP:
          Serial.println("Obtained IP address");
    default: break;
  int TryCount = 0;
  Serial.println( "connect to wifi" );
    TryCount++;
    WiFi.disconnect();
    WiFi.begin(WIFI_NETWORK, WIFI_PASSWORD);
Serial.println( TryCount);
    delay(4000);
      ESP.restart();
  WiFi.onEvent(WiFiEvent);
    connectToWiFi();
I tried another esp32 board it counts to 10 and then restart, but the first one only counts to 1
@Idahowalker
why would you want it to count to more than 1?
What's the count for?
Notice how the count is incremented each time the loop tries to make a WiFI connection? Notice how if it gets to 10 it causes a reset? It only counts to 10 when it cannot connect.
It only counts to 1 because?
A, a connection is made.
B, no connection is made
C, clueless
