Connect ESP8266 to Arduino Uno
I have connected the ESP8266 to Arduino Uno Like :
Acc to 3.3v
RX to TX
TX to RX
GND to GND
CH-PD to 3.3v
RST to 3.3v
and I only receive garbage :roll_eyes:
I have tried to connect
RX to RX and TX to TX --> Same garbage !!
Please help.
Baud rates?
Sorry, I am a beginner.
What do you mean with "Baud rates" ?
Baud rate = serial data transmission and reception rate. The sender and receiver Baud rates have to be known, correct and match.
I have tried 115200, 9600 and others --> Same problem
If you are using the Arduino Uno as the USB-to-serial converter, I found it best to remove the Atmega. I have the DIP version.
Did you download the support software for the ESP8266 family using the Arduino's IDE? Most tutorials ignore this step.
My RST line is not connected. I have a ESP8266 EPS-01.
You definitely need a 3.3V power supply.
And you need to level shift the RX from 5V to 3.3V. A voltage divider would work.
How can I download the support software for the ESP8266 family using the Arduino's IDE?
se_fore_jj:
Board Manager.
Acc to 3.3v
RX to RX
TX to TX
GND to GND
CH-PD to 3.3v
Now it works but when I am typing AT command I get "Error" Not "OK"
can any one help, Please?
se_fore_jj:
Acc to 3.3v
RX to RX
TX to TX
GND to GND
CH-PD to 3.3v
The ESP8266 must have its own power supply. It draws too much current to be connected to the 3.3V on the Arduino.
Also, the ESP-01 I have use 152000 baud rate.
I have same problem!
heninsh:
Hello!
I have an esp8266 wifi module from ebay http://www.ebay.com/itm/ESP8266-Serial-WIFI-Wireless-TransceiveR-Module-Send-Receive-LWIP-AP-STA-SS/222084050344?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35625%26meid%3D8cc61da99a9f48d88f42c8f11247b41a%26pid%3D100011%26rk%3D1%26rkt%3D10%26sd%3D262105141657 and I want to get my esp 8266 module work.
For most tutorial they use FTDI. But I don't have it. :frowning:
I use this type of connection:https://files.fm/u/gft7d9rf#/
When I open Serial monitor and reset my esp8266 it's send me ready: https://files.fm/u/gk5v3cvx#_https://files.fm/u/gk5v3cvx#_
And when I start write AT commands nothing happens !
Before I did this I was tryed this tutorial, but also without results: https://www.youtube.com/watch?v=cxVABKNy7OI&index=27&list=PLUiiWOj4UZOOUbEn_eS5Ou8FYHO4vZjSE
I hope you will help me with your experience!
What i did:
heninsh:
Okey, I tryed powered esp8266 wifi module with power supply. Now on esp8266 wifi module red and blue leds is on and nothing happens when I change parametrs in serial monitor. Esp8266 wifi module didn't send READY! AT commands doesn't work too.
I think now I need to upload 9.2. version and everything must work. I made schematic for programming on my breadboard. I entered the flash programming mode by holding down the PROG button and then pressing and releasing the RESET button. Then to verify the flash programming was successful, I needed to talk to the chip and query the firmware version. I closed the flash programming window and pressed the RESET button (without pressing the PROG button) to place the ESP8266 board in user mode. Everything works fine.
But i don't have FTDI or arduino uno with th atmega328, so i can't try it now!
Acc to 3.3v
RX to RX
TX to TX
GND to GND
CH-PD to 3.3v
and use 152000 baud rate it now works fine.
Thank you!
