Connect Grove i2c hub to Arduino
Hi everyone.
Is it possible to connect this grove hub
https://www.seeedstudio.com/Grove-I2C-Hub-p-851.html
to an arduino without using any base shield (like this) https://www.seeedstudio.com/Base-Shield-V2.html
It would be very useful. Thanks!
nicolopadovandev:
Hi everyone.
the connectors on the hub are all on same two pins.
without the base shield you can use this cable to connect to one of the connectors and then connect 3 I2C modules
Thanks!
The male pins of the cables that you send me should go in which female pins on the arduino? (uno in this case)
nicolopadovandev:
Thanks!
I2C pins SCL yellow, SDA white and 5 V red and Ground black
Thanks!
