Hi all,
I am using HC-05 Bluetooth module with the MKR board to achieve the data transmission between the Arduino and an Android phone. The library I am using is
#include<SoftwareSerial.h>But when I upload the configuration code of HC-05, there is en error saying "This version of SoftwareSerial supports only 20, 16 and 8MHz processors". I don't know if this library doesn't work for MKR Zero board? If not working, how can I use HC-05 module?
The following is the configuration code from online
#include <SoftwareSerial.h>
//Change these to whatever pins you're using
SoftwareSerial blueSerial(13, 14); // RX, TX
blueSerial.begin(38400);
// pinMode(9, OUTPUT);
// digitalWrite(9, HIGH);
if (blueSerial.available())
Serial.write(blueSerial.read());
if (Serial.available())
blueSerial.write(Serial.read());
