I tried to connect Arduino UNO R4 WiFi to my ESP32 IoT server, using its IPAddress. This failed.
My UNO R4 uses firmware 0.3.0.
I tried also the example WiFiWebClient.ino.
This works when using the server name, but not using the IP address:
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
//char server[] = "www.google.com"; // name address for Google (using DNS)
IPAddress server(142,250,203,100); // numeric IP for Google (no DNS)
I retrieved the updated IP address with:
if (client.connect(server, 80))
Serial.println("connected to server");
IPAddress ip = client.remoteIP();
Serial.print("server IP Address: ");
Serial.println(ip);
Has anyone encountered this issue, or any idea to analyze or solve it? Thank you.
-jz-
I was not sure if the IP address in the example is correct. So I connected using the name and retrieved the server IP. But using this IP address also failed.
Yes. Yes. Yes. Yes. These for my initial test to connect to my IoT server.
The usual recommendation would be to use an example from WiFiS3. This is what I did!
Then I took the WiFiWebClient.ino example.
This example should work in two ways, either with a DNS name or with an IP address for www.google.com, according to the commented out line
Windows Edge doesn't show the IP address, so I can't check if this address is correct.
I have not yet decided to open an issue against this example.
@Juraj, thank you for this information! Appreciated.
Could you report which version of the firmware was used?
I had to modify the example slightly to get it to work on ESP32 (Wemos LOLIN32 Lite).
The example works with IPAddress on ESP32, but not on Arduino UNO R4 WiFi (firmware 0.3.0)
Web client
This sketch connects to a website (http://www.google.com)
using the WiFi module.
This example is written for a network using WPA encryption. For
WEP or WPA, change the WiFi.begin() call accordingly.
created 13 July 2010
by dlf (Metodo2 srl)
modified 31 May 2012
by Tom Igoe
Find the full UNO R4 WiFi RTC documentation here:
https://docs.arduino.cc/tutorials/uno-r4-wifi/wifi-examples#wi-fi-web-client
#if defined(ARDUINO_UNOR4_WIFI)
#include "WiFiS3.h"
#else
#include <WiFi.h>
#endif
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key index number (needed only for WEP)
int status = WL_IDLE_STATUS;
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS) obsolete
IPAddress server(142,250,203,110); // numeric IP for Google (no DNS)
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
#endif
// attempt to connect to WiFi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
status = WiFi.status(); // needed for ESP32
printWifiStatus();
Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
Serial.println(ip);
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
/* just wrap the received data up to 80 columns in the serial print*/
void read_response() {
uint32_t received_data_num = 0;
while (client.available()) {
/* actual data reception */
char c = client.read();
/* print data to serial port */
Serial.print(c);
/* wrap data to 80 columns*/
received_data_num++;
if (received_data_num % 80 == 0) {
read_response();
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting from server.");
client.stop();
// do nothing forevermore:
while (true);
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
NO, although that's not what he asked,
I got the impression he was asking if anyone had ACTUALLY Successfully connected using I.P. addressing
I didn't go into more detail as it looks like everything i would have told him you already are.
Google actually has many I.P. Addresses and even though i know approx 15 of them
this is not one that i instantly recognized
My first thought was, that he went and posted his Public I.P.
i mean, ... that's a very common thing for a person asking this sort of question to do.
In any case, No problem
I would also suggest that he learn to use cmd.exe and utilize ping www.google.com Enter
Initially i assumed it was, and i was being cautious.
as this is a very common mistake of people to make who are asking questions relating
to ESP32 and Using the WiFi capability.
it happens because people want to be as open and transparent as possible
so you can understand how IT COULD HAVE BEEN YOUR I.P. right ?
