I'm trying to connect my LCD to the Mini-Pro using SCL and SCA
but I can't see the LCD.
if I take it to my Arduino Ethernet (with the same cables) it's work. - so the LCD and cables are O.K
how do I know if I need to add a pullup ?(when I work with the Ethernet I don't use any)
from what I have found online - if the LCD work on the Arduino Ethernet without any resistors it should work on the Mini-Pro without it.
when I run the I2C_scanner.ino
it get stuck - I have check the wires and there isn't short circuit , or something .
what could be the problem ?
Thanks,
You did not mix SCL and SCA?
And how do you mean, get stuck??
I didn't mix (I have look many times)
and as you can see on the last line - this is what I mean "stuck"
Found 0 device(s).
Found 0 device(s).
Done.
Found 0 device(s).
Done.
Found 0 device(s).
Done.
Found 0 devi
I made the code run in loop ,
and when I connect the LCD (SCL+SDA) it's stuck
And did you connect the power en GND to Vcc and GND of the pro Mini?
And it's not by any change a 3,3V Pro Mini?
it's 5V for sure
and just to be clear -
A4 -SCl
A5-SDA
Right?
because when I search examples on google I see the other way around
I have A4 = SDA and A5 = SCL, same as the Uno... So that is the wrong way around
