Connect Leonard, Uno, Mega or general avr Arduinos to Yun
Hi, All,
For those who want to use the General Arduino Board to use Yun features, I would like to introduce the Yun Shield to you. :slight_smile:
Yun Shield is an Arduino Shield which will simply turn Arduino board into "Arduino Yun" .
Usage:
Structure
Documents
Datasheet: http://www.dragino.com/downloads/index.php?dir=YunShield/&file=YunShield_datasheet.pdf
Quick Start Guide: Dragino Download Server ./downloads/YunShield/
User Manual: Dragino Download Server ./downloads/YunShield/
Hardware Source modules/hardware/YunShield at master · dragino/modules · GitHub
Cheers
LP
cool
Do you have a SD card reader? If not you can not say it is a yun shield.
Jantje:
cool
You can use the USB port for storage. Which will act same as SD card.
Support external antenna is big plus!
szlp:
Jantje:
cool
Well, not really... :~
Ralf
Good, but I also think it needs an SD card slot.
With a card slot, it would solve my current problem, which is that I need the features of a Mega connected to the linux side of a Yun. The Yun would be serving the data, both live and historical, so needs an SD card for data storage.
Unfortunately, a USB storage device won't fit inside the standard box.
DarkCloud:
I agree a USB is not a replacement of a sd slot. If you have a USB device you would need a USB hub that needs power ......
This Linux shield has a SD slot and USB. Maybe this is a solution for you.
Best regards
Jantje
Thank you for that, Jantje. It looks perfect for what I want.
Dark Cloud has silver lining :smiley:
