Hi all,
I am trying to control a serial dac using arduino nano. I wrote my program but unable to get it working:
#include <SPI.h>
const int ldacPin = 3;
const int sclkPin = 4;
const int dinPin = 5;
const int csPin = 6;
const int clrPin = 7;
const int uniPin = 8;
SPI.begin();
SPI.setBitOrder(MSBFIRST); // from the Data Sheet
pinMode(10,OUTPUT); //as pin 10 is not used
pinMode(ldacPin,OUTPUT);
pinMode(sclkPin,OUTPUT);
pinMode(dinPin,OUTPUT);
pinMode(csPin,OUTPUT);
pinMode(clrPin,OUTPUT);
pinMode(uniPin,OUTPUT);
digitalWrite(csPin, HIGH);
delay(timer); //100us delay as per MAX5312 datasheet
digitalWrite(ldacPin, HIGH);
digitalWrite(clrPin, HIGH);
digitalWrite(dinPin, HIGH);
digitalWrite(uniPin, HIGH); //To set DAC to unipolar mode pin 8 on the dac
SPI.transfer(0x4B33);
/* Above: First 3bits(from msb) is control bits last 12 bits is 2867 so expected the output voltage is around 7 volts
delay(2);
digitalWrite(csPin, LOW);
digitalWrite(sclkPin,HIGH);
delay(2);
digitalWrite(sclkPin,LOW);
From the datasheet, the dac output is updated with control bits 0x400 (0100). For a 2867 code (0xB33), I set to transfer the full 16 bits in one go 0x4B33 when the CS is low and latch on the dropping edge of SCLK.
Thanks
If it's an SPI DAC, why are you not using the SPI pins: D13 = SCK, D12 = MISO, D11 = MOSI, and generally D10 is used for SS as it has to be set to an output on the master SPI device anyway.
Post a link to the MAXIM website for that device.
From this
and you put the 4 bits + 12 bits together into an int however you'd like.
Perhaps:
int command = 0bxxxx000000000000; // xxxx is command bits from datasheet Table 2
int data = 0b0000xxxxxxxxxxxx; // xxxx xxxx xxxx is desired DAC output.
int commandPlusData = command | data;
If I understand, on the arduino, the MOSI pin (11) is connected to the DIN pin on the max5312. The rest are MISO=DIN, ss=CS.
The max5312 datasheet: http://datasheets.maximintegrated.com/en/ds/MAX5312.pdf
I have inserted the suggestion as follow but still no luck
#include <SPI.h>
const int ssPin = 10;
const int misoPin = 11; //To connect the DIN pin from the DAC
const int sclkPin = 13;
int command = 0b0100000000000000; // 0100 Load input and DAC registers from shift register; DAC output updated.
int data = 0b0000101100110011; // 2867 desired DAC output.
SPI.begin();
SPI.setBitOrder(MSBFIRST); // from the Datasheet
pinMode(misoPin,OUTPUT);
pinMode(ssPin,OUTPUT);
digitalWrite(ssPin, HIGH);
delay(100); //100us delay as per MAX5312 datasheet
digitalWrite(misoPin, HIGH);
digitalWrite (ssPin, LOW); // pin 10
SPI.transfer (highByte (commandPlusData));
SPI.transfer (lowByte (commandPlusData));
//digitalWrite (ssPin, HIGH);
delay(2);
digitalWrite(ssPin, LOW);
delay(2);
digitalWrite(ldacPin, LOW);
Datasheet says on DIN pin the clock data in on the rising edge of SCLK.
Thanks
MISO is not used, leave the pin unconnected.
Connect Arduino's MOSI to DIN on the chip.
DOUT from the chip is not connected to anything for now.
Get rid of these, SPI library sets them up:
Don't need - MSBFIRST is default setting
Delete these - not needed with software command 0100:
LDAC & CLR only need to be HIGH:
delay(2);
Add to go with these:
digitalWrite (ldacPin, HIGH);
digitalWrite (clrPin, HIGH);
Get rid of this, is taken care of by SPI library
Get rid of these - not needed with software command 0100 being used:
delay(2);
digitalWrite(sclkPin,HIGH);//Data clocked rising edge
delay(2);
digitalWrite(ldacPin, LOW);//Force update
Add this in setup:
pinMode (ssPin, OUTPUT);
digitalWrite (ssPIN, HIGH);
Add this after the SPI.transfers
I realised earlier after the post I had to connect SHDN to 5v just in case as it was ambiguous in the pin description or my understanding
You are the man CrossRoads. Much appreciated.
It is now working.
My next step is now to have it to increment up to a set value.
Thanks for the help
