Connect MAXREFDES131 to Arduino
Hello,
I got a MAXREFDES131 which is an EyeGrid Sensor. I am new to the Arduino world and have no idea on how to connect the component to my Arduino UNO.
Here is all the info I've got on the MAXREFDES131
https://www.maximintegrated.com/en/design/reference-design-center/system-board/6331.html/tb_tab1
The tutorial only says : connect your MAXREFDES on your Arduino board...
Thanks in advance for your answers !
Also on SE: https://arduino.stackexchange.com/questions/47465/how-to-connect-maxrefdes131-to-arduino
The information you posted says the MAXREFDES131 must use the MAXREFDES130#, MAXREFDES132#, or equivalent 1-Wire hardware interface. For Arduino, this interface must use the DS2484 I2C-to-1-Wire master.
Do you have a 130, 132 or equivalent and are you using them?
Hi! Thank you for your answer! I just acquired the MAXREFDES132. It has an RJ11 port meant to connect the MAXREFDES131 I presume. But, I don't know how to link the MAXREFDES132 to the Arduino board.
Can you please help ?
