Connect mcp3551
I have a MCP3551 (22 bits adc) and it is equipped with the following connections to be interfaced with an Arduino - SCK - SDO/!RDY - !CS. Has someone used this before and can you tell me with library and which output to use?
Hey ssijbesma,
Maybe this link will help: http://forum.arduino.cc/index.php?topic=164643.0
Good luck!
Problem solved: :wink:
This example demonstrate the usage of the A/D Converter with MCP3551 library.
#include <MCP3551.h>
#include <SPI.h>
const int MCPPin = 10;
Connect SCK to CLK (pin 13 on Uno)
Connect SDO/!RDY to MOSI (pin 12 on Uno)
Connect !CS to MCPPIN (pin 10 on Uno)
//Create an instance of MCP3551 connected to the MCPPIN
MCP3551 myADC(MCPPin);
if(myADC.getCode())
Serial.println(myADC.byteCode);
delay(200);
ssijbesma Can you share that library?
Thanks!
