Connect MKR ETH Shield with Leonardo
By mistake, I bought a MKR Ethernet Shield, but I have a Arduino Leonardo. How I connect the both? Which Leonardo Pin I need to connect with which MKR Ethernet Shield Pin?
Thank you for help!
MKR ETH shield is for 3.3 V boards (in MKR form factor). buy an Ethernet 2 shield for Leonardo
http://forum.arduino.cc/index.php?topic=596027.msg4048374#msg4048374
Juraj: MKR ETH shield is for 3.3 V boards (in MKR form factor).
The Leonardo has a 3.3 V Output, and I have some wires.
Benjamin_6848: The Leonardo has a 3.3 V Output, and I have some wires.
read the thread linked in my comment
the MKR ETH is powered with 5 V and the W5500 is 5 V tolerant, but inserted SD card will not work or could be damaged.
to wire it connect 5 V, ground, SPI pins, reset and CS pin
https://www.arduino.cc/en/reference/SPI
all pins except of CS pin are on the ICSP header use pin 10 as CS. it should be the default for Leonardo in Ethernet library
|500x285
