Is it possible to connect two pms7003 sensors into 1 arduino board and collect both sensors'data at once?then what is the board I should buy? Is there any help available,kindly send me links
Welcome to the forum
Why did you start a topic in the Uncategorised category of the forum when its description explicitly tells you not to ?
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
Since the device uses a serial connection, you will need an Arduino board with one serial connection for each device, in addition to a connection to your PC. The documentation PDF is your guide! Allow for the voltage on the serial connection of 3.3 volts.
