Connect New NodeMCU V3 with Bluetooth module HC-05
Hello everybody!
I hope I am posting this in the right place in the forum…
I am trying to connect a Bluetooth module HC-05 to a microcontroller New NodeMCU V3, and I have the following question:
The pins that the Bluetooth module uses to send/receive work with 3.3V. Can I connect these to the microcontroller’s New NodeMCU pins? I haven’t found New NodeMCU’s specifications anywhere, and I’m afraid I can damage the module or the New NodeMCU microcontroller.
Thank you!
NodeMCU uses 3.3V logic levels. To triple check that you can use a scetch where you output HIGH and then use a multimeter.
