I am now to this ESP32 stuff and need your help. I would like to make an living photo frame with esp32, TFT display and SD card module. The idea is to format and copy photos to SD card and let it loop or shuffle always.
The display pins include VCC, GND, SDA, SCL, RST, DC, CS, BL and SDA-O (ST7796S, 3.5in, non touch)
The SD module pins include VCC, CS, MOSI, MISO, SCK, and GND
I tried the code for SD module only --> it works, for tft display only --> it works
But tried to combine it, the TFT initiate and inform the SDcard failed. Please show me some light at the end of the road.
can you give a link to the TFT?
is the SD reader onboard the TFT or a separate module - if so give a link?
if the TFT has an onboard regulator it may need 5V power (BL is usually 3.3V)
you may have to connect the TFT to VSPI and the SD reader to HSPI
Run the TFT on the standard default SPI and the SD card on the HSPI bus, long term reliability is better that way.
I am guessing here, because you have not posted the code (hint!) but if your thinking of using the TFT_eSPI library to display images on the TFT, you might find it only works with earlier versions (2.0.14 and below) of the ESP32 Core.
