Is there any possibility to connect RN171 Wifi Shield by Seeeduino Studio to Blynk or IoT Cloud? I wish to control LED remotely.
only a very few boards are supported on IoT cloud and all of them have WiFi on board.
do you have some problem connecting it to Blynk with Blynk examples? the WiFly library for RN171 is supported by Blynk
I tried this code after choosing RN-XV WiFly in Blynk examples
... I replaced of course.
The RN171 seems like was recognised although the connection is always failed in serial monitor. I tried multiple networks as well.
#define BLYNK_TEMPLATE_ID "..."
#define BLYNK_DEVICE_NAME "..."
#define BLYNK_AUTH_TOKEN "..."
// Comment this out to disable prints and save space
#define BLYNK_PRINT Serial
#include <WiFlyHQ.h>
#include <BlynkSimpleWiFly.h>
char auth[] = BLYNK_AUTH_TOKEN;
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "...";
char pass[] = "...";
//#define WiFlySerial Serial1
// This can be a SoftwareSerial object:
#include <SoftwareSerial.h>
SoftwareSerial WiFlySerial(2, 3); // RX, TX
WiFly wifly;
// Debug console
WiFlySerial.begin(9600); // Set your RN-XV baud rate
delay(10);
// Bind WiFly driver to the serial
if (!wifly.begin(&WiFlySerial)) {
BLYNK_FATAL("Failed to start wifly");
// You can try increasing baud rate:
//wifly.setBaud(115200);
//WiFlySerial.begin(115200);
Blynk.begin(auth, wifly, ssid, pass);
Blynk.run();
This code (example from WiFly) connect the RN171 to my network successfully although I'm not sure how to make the connection to Blynk.
#include <Arduino.h>
#include "WiFly.h"
#define SSID "..."
#define KEY "..."
#define AUTH WIFLY_AUTH_WPA2_PSK
SoftwareSerial uart(2, 3);
WiFly wifly(&uart);
uart.begin(9600);
Serial.println("--------- WIFLY TEST --------");
// wait for initilization of wifly
delay(3000);
uart.begin(9600); // WiFly UART Baud Rate: 9600
wifly.reset();
Serial.println("Join " SSID );
if (wifly.join(SSID, KEY, AUTH)) {
Serial.println("OK");
Serial.println("Failed");
// get WiFly params
wifly.sendCommand("get everthing\r");
char c;
while (wifly.receive((uint8_t *)&c, 1, 300) > 0) {
Serial.print((char)c);
if (wifly.commandMode()) {
Serial.println("Enter command mode. Send \"exit\"(with \\r) to exit command mode");
while (wifly.available()) {
Serial.write(wifly.read());
while (Serial.available()) {
wifly.write(Serial.read());
you have to setup a Blynk account, template and device on cloud and put templateid and deviceid into the sketch
