Hi, I am facing issues with the write() function. How can I rotate the servo motor? Can anyone help me figure out the error?
// Could not connect to serial port 'Digital pin 9' due to error: "port" must be None or a string, not <class 'pyfirmata.pyfirmata.Pin' //
import pyfirmata
from servomotor_communication import ServoMotorCommunication
from pyfirmata import SERVO
class ServoMotorController(ServoMotorCommunication):
def __init__(self, serial_port=None, baud_rate=9600, board=None, servo_pin=None):
super().__init__(serial_port, baud_rate, board, servo_pin)
self.__angle = None
self.__servo_pin = None
def rotate_servo(self,angle):
if angle < 0 or angle > 180:
raise ValueError("Angle must be between 0 and 180 degrees.")
self.__angle = angle
self.serial_port= pin
print(self.__servo_pin,self.__angle)
self.board.digital[serial_port].mode = SERVO
self.board.digital[serial_port].write(angle)
def test_servo(self):
while True:
print("\t 1: Open the doors")
print("\t 2: Close the doors")
choice = input("Enter your choice:")
if not choice.isdigit():
print("Must be a valid number")
continue
try:
choice = int(choice)
if choice == 1:
self.rotate_servo(180)
elif choice == 2:
self.rotate_servo(0)
else:
raise ValueError("Invalid choice. Please choose 1 or 2.")
except ValueError as ex1:
print(ex1)
continue
serial_port = '/dev/tty2'
baud_rate = 115200
board = pyfirmata.Arduino(serial_port)
pin = board.get_pin('d:9:s')
start_communication: ServoMotorCommunication = ServoMotorCommunication(serial_port=serial_port, baud_rate=baud_rate,
board=board, servo_pin=pin)
start_control = ServoMotorController()
#message = f"The Servo Motor is connected to {serial_port} on pin {pin} with baud rate of {baud_rate}"
#start_control.logger.log_info(message)
start_control.test_servo()
