I have a working script that connects to a PHP script and check's if i have new emails..
Now i'm wondering ( as a newbie in Arduino ) how i can repeat this script every minute?
This is my script
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
0x90, 0xA2, 0xDA, 0x0F, 0x5C, 0x67 };
//IPAddress server(192, 168, 0, 187);
char server[] = "192.168.0.187";
EthernetClient client;
boolean reading = false;
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
while (!Serial) {
// start the Ethernet connection:
Ethernet.begin(mac);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
client.println("GET /learning/arduino_get/imap.php HTTP/1.0");
client.println();
client.println("Connection: close");
else {
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
if(reading && c == ' ') reading = false;
if(c == '?') reading = true;
if(reading){
Serial.print(c);
switch(c) {
case '1':
digitalWrite(6, HIGH);
case '2':
digitalWrite(7, HIGH);
case '3':
digitalWrite(8, HIGH);
Below is event based client code that makes a GET request when an e is sent via the serial monitor. Should be easy to adapt a milli timed event similar to the blink without delay example code.
//zoomkat 11-04-13
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test client GET
//for use with W5100 based ethernet shields
//remove SD card if inserted
//data from myIP server captured in readString
#include <SPI.h>
String readString;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // zoomkat's test web page server
void setup(){
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
while(true);
Serial.println("client readString test 11/04/13"); // so I can keep track of what is loaded
Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
// check for serial input
if (Serial.available() > 0) //if something in serial buffer
byte inChar; // sets inChar as a byte
inChar = Serial.read(); //gets byte from buffer
if(inChar == 'e') // checks to see byte is an e
sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
if (client.connect(serverName, 80)) { //starts client connection, checks for connection
client.println("GET / HTTP/1.1"); //download text
client.println("Host: checkip.dyndns.com");
client.println("Connection: close"); //close 1.1 persistent connection
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
readString += c; //places captured byte in readString
//Serial.println();
client.stop(); //stop client
Serial.println("client disconnected.");
Serial.println("Data from server captured in readString:");
Serial.print(readString); //prints readString to serial monitor
Serial.println("End of readString");
Serial.println("==================");
readString=""; //clear readString variable
