Connect to linvor
Hello! This is the device that I use:
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=261024357609&ssPageName=ADME:L:OU:US:1123
If i open the bluetooth of my pc, identify the device and open the port via putty or any other terminal the devices seem to be connecting. From any other device, such as my phone, I am seeing linvor as a device but If i try to connect I cannot. My opinion that somehow I must open the port, and my question is how to do it? From my pc, from arduino code, from my android code, where?
And how can I leave it open because I want it to be able to work without having to do it again and again.
Thanks.
Do you have more than this page. There is no exact type of this device. Seems that one of the standard bluetooth modules is soldered on it but these come in a variety of flavours each with different modes and commands. You should at least provide a link to a datasheet or give us the exact type of the module on it.
You should also describe in more detail what you wanna achieve, what exactly you try and what response you get from your computer (specify operating system) or other device. Also you should post the Arduino code your using to test this.
see my replies to the following questions - it should have what you need:
http://arduino.cc/forum/index.php/topic,109372.0.html
http://arduino.cc/forum/index.php/topic,109621.0.html
Good luck!
Brian Williams
I am facing same problem as "VIMA", plz anyone help us...is linvor 1.5 is defective or there is a issue with android 2.3 to not support Bluetooth SPP.
BWIMS, i gone through ur link but not got any idea to resolve my issue.Plz guide me.
vima: the devices seem to be connecting. From any other device, such as my phone, I am seeing linvor as a device but If i try to connect I cannot. My opinion that somehow I must open the port, and my question is how to do it? From my pc, from arduino code, from my android code, where?
The device is an HC-06.
All you need to is ensure it is correctly wired, Rx to Tx and Tx to Rx, and you should be cooking with gas.
There is no "seems" to be connecting. It either is or it isn't, and when it does the flashing LED is much slower than the fast idle signal. You will probably need to trawl for the port in Putty, which I guess is much the same as RealTerm. Try COM 40. You don't do anything at the Arduino end, except disconnect the USB cable, you just send the same information exactly as you would send it to the serial monitor. You can read the bluetooth on your laptop at the same time as you read the screen on the desktop, but not both on the same machine.
I hear BlueTerm is the way to go with Android but I have never succeeded with it, although Android can see the Linvor.
There nothing to do with leaving it open, the bluetooth is running as long as Arduino is running, and you just listen in as you need.
I have quite some expertise on the linvor and am happy to try to help, but maybe this problem is already solved?
Let me know if you still need help.
By the way, the linvor is only good for the most basic of bluetooth comms and it generates tons of EMI, so don't expect too much from it.
I have now swtiched to a Sparkfun BlueSRMIF which is far far superior in all respects.
Ciao, Bob
