Hello
I built with success movement sensor with VM204 (MM7455 sensor) and Arduino UNO using A4, A5 analog inputs.
I transpose this montage on Arduino Micro and use sames Analog Input port A4, A5 (#9 and #10).
That doesn't work.
Is there difference in naming rules between the two arduino cards ?
Thanks for help
SDA and SCL are pins 2 and 3 on the Micro board.
Google "Arduino Uno pinout" or "Arduino Micro pinout", and click "images".
Leo..
MM7455 sensor works on I2C Protocol.
If you check Arduino UNO Pinout, then you will see:
- A4 is SDA short for Data Line.
- A5 is SCL short for Clock Line.
Now if you check Arduino Micro Pinout:
- Pin # 2 is SDA.
- Pin # 3 is SCL.
I hope you can now make the connections.
Thanks a lot
It's fine.
