Connect Vibration Motor to Arduino
I want a vibration motor to interact with a distance sensor. The vibration motor activates when the distance sensor measures a distance below 20 cm.
The code below does what I said above,except that it lights up an LED called “vibrator1.” I thought I could easily replace the LED with a vibration motor, but that doesnt work. What should I do? Is this a coding issue, a connection issue, or both?
#define trigPin1 2 //initialize pins
#define echoPin1 3
#define trigPin2 4
#define vibrator1 8
long duration, distance, Sensor1;
Serial.begin (9600);
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
SonarSensor(trigPin1, echoPin1);
Sensor1 = distance;
if (Sensor1 < 20)
DigitalWrite(vibrator1, HIGH);
DigitalWrite(vibrator1, LOW);
Serial.print(Sensor1);} //print distance
void SonarSensor(int trigPin,int echoPin) //calculates distance from sensor
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH); //emits ultrasonic wave
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH); //pulseIn calculates the time between sending and receiving
distance = (duration/2) / 29.1; // use the time and velocity of the ultrasonic wave to find distance
delay(250);}
You ought to elaborate about what “doesn’t work” really means, but I’d guess that your motor is trying to draw too much current from a digital pin. What are the symptoms?
What does the motor’s datasheet say about current requirement?
What should I do?
Probably need to drive the vibrator with its own power, controlled by a transistor.
Your code, which you clearly never tested, doesn't set the vibra pin to be an output.
AWOL: Your code, which you clearly never tested, doesn't set the vibra pin to be an output.
Keen eye. This is part of a larger code, I missed that line while copy/pasting.
CGL2017: Keen eye. This is part of a larger code, I missed that line while copy/pasting.
So then what about current as I suggested in #1?
You didn't say what model motor you have, but details of two that I found have current of about 75mA, 100 at startup iirc, which is 2 or even almost 3 times the current a digital pin can provide, 4-5 times the recommended.
CGL2017:
It’s not just one line. Your copy paste also seems to have a toupper functionality.
