Connected arduino with thingspeak (simple)
Hello, my name is Arief. I am from Indonesia. I have a project and am having trouble uploading data to Thingspeak via w5100 ethernet.
I do not make ip static to connect with thingspeak. Initially Thingspeak managed to display the data. But after 3 minutes, Thingspeak does not display data. Is the procedure wrong?
i have code :
#include <SPI.h>
#include <Ethernet.h>
int pin = 0; // analog pin
int tempc = 0,tempf=0; // temperature variables
int samples[8]; // variables to make a better precision
int maxi = -100,mini = 100; // to start max/min temperature
int i;
// Local Network Settings
byte mac = { 0xD4, 0xA8, 0xE2, 0xFE, 0xA0, 0xA1 }; // Must be unique on local network
byte ip = { 192,168,0,230 }; // Must be unique on local network
byte gateway = { 192,168,0,1};
byte subnet = { 255, 255, 255, 0 };
// ThingSpeak Settings
char thingSpeakAddress = “api.thingspeak.com”;
String writeAPIKey = “C09IRCIHKMPF19HP”; // Write API Key for a ThingSpeak Channel
const int updateInterval = 10000; // Time interval in milliseconds to update ThingSpeak
// Variable Setup
long lastConnectionTime = 0;
boolean lastConnected = false;
int failedCounter = 0;
// Initialize Arduino Ethernet Client
EthernetClient client;
Ethernet.begin(mac, ip, gateway, subnet);
Serial.print("ETHERNET SHIELD ip is : ");
Serial.println(Ethernet.localIP());
// Start Ethernet on Arduino
startEthernet();
tempc = ( 5.0 * analogRead(pin) * 100.0) / 1024.0;
String analogPin0 = String(tempc);
// Print Update Response to Serial Monitor
if (client.available())
char c = client.read();
Serial.print(c);
// Disconnect from ThingSpeak
if (!client.connected() && lastConnected)
Serial.println("…disconnected.");
client.stop();
// Update ThingSpeak
if(!client.connected() && (millis() - lastConnectionTime > updateInterval))
updateThingSpeak(“field1=”+analogPin0);
lastConnected = client.connected();
void updateThingSpeak(String tsData)
if (client.connect(thingSpeakAddress, 80))
client.print(“POST /update HTTP/1.1\n”);
client.print(“Host: api.thingspeak.com\n”);
client.print(“Connection: close\n”);
client.print(“X-THINGSPEAKAPIKEY: “+writeAPIKey+”\n”);
client.print(“Content-Type: application/x-www-form-urlencoded\n”);
client.print(“Content-Length: “);
client.print(tsData.length());
client.print(”\n\n”);
client.print(tsData);
lastConnectionTime = millis();
if (client.connected())
Serial.println(“Connecting to ThingSpeak…”);
failedCounter = 0;
failedCounter++;
Serial.println(“Connection to ThingSpeak failed (”+String(failedCounter, DEC)+")");
failedCounter++;
Serial.println(“Connection to ThingSpeak Failed (”+String(failedCounter, DEC)+")");
void startEthernet()
client.stop();
Serial.println(“Connecting Arduino to network…”);
// Connect to network amd obtain an IP address using DHCP
if (Ethernet.begin(mac) == 0)
Serial.println(“DHCP Failed, reset Arduino to try again”);
else {
Serial.println(“Arduino connected to network using DHCP”);
Serial.println(“Data being uploaded to THINGSPEAK Server…”);
Does your program produce any error messages when the data isnt sent to Thingspeak?
Suggest you add some code to read the response in case that gives you a clue. I didnt see where you do client.stop() after you send either.
   client.print("Content-Length: ");
    client.print("\n\n");
    client.println(tsData);  // change this to println
    // add this to print out response
    while (client.available()) {
      Serial.print(c);
