Connecting 128*64 LCD to Arduino Mega 2560 R3
Hi All,
I am trying to use http://www.bajdi.com/wp-content/uploads/2013/03/glcd-128x64.jpg this LCD display with my Arduino Mega 2560 R3. I tried to use this library in my work http://playground.arduino.cc/Code/GLCDks0108. I have connected the LCD and Arduino as mentioned in IMPORTANT NOTE section of the above tutorial.
But when I tried to run this hello world program there. It shows a bright and dark dots all over the LCD. I tried different codes. But situation is the same. What has gone wrong in here?
GLCD Library - Hello World
This sketch prints “Hello World!” to the LCD
and shows the time in seconds since reset.
The circuit:
See the inlcuded documentation in glcd/doc directory for how to wire
up the glcd module. glcd/doc/GLCDref.htm can be viewed in your browser
by clicking on the file.
// include the library header
#include <glcd.h>
// include the Fonts
#include <fonts/allFonts.h>
// Initialize the GLCD
GLCD.Init();
// Select the font for the default text area
GLCD.SelectFont(System5x7);
GLCD.print(“hello, world!”);
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
GLCD.CursorTo(0, 1);
// print the number of seconds since reset:
GLCD.print(millis()/1000);
What is the make/model number of your LCD? (the photo has pinouts, but no model number).
It has a PSB pin, so it is a ST7920 based display. The ST7920 controller is not supported by GLCDks0108 library. You could use u8glib (http://code.google.com/p/u8glib/)
In the examples use "U8GLIB_ST7920_128X64_1X(sck, mosi, cs [, reset])"
Follow the instruction for this controller on this page http://code.google.com/p/u8glib/wiki/device (below the table)
Oliver
Thanks oilkarus your solution works fine!
