Connecting 14 pin LCD 19264 model ADT-G19264D-03
Please, help me to connect 14 pin LCD 19264 model ADT-G19264D-03 to arduino.
I have some questions:
  1. This display uses negative polarity power supply? Which typical value voltage for VLCD? This voltage is necessary or display can work without it?
  2. Is there a library to work with 14-pin displays? I found same display LM240128NCC, there is description of logic in datasheet, but I don't have enough knowledge to write library for this display.
Datasheets: http://www.lcdmk.com/tbpic/adt-G192064D-03.pdf http://www.topwaydisplay.com/Pub/Manual/LM240128NCC-1-Manual-Rev0.1.pdf
The G1929064D is a controllerless display. Using such a display is almost impossible with any Arduino Board. There are also no libraries. Look out for displays with graphics controller and SPI, I2C or 8080/6800 interface.
Oliver
olikraus: The G1929064D is a controllerless display. Using such a display is almost impossible with any Arduino Board. There are also no libraries. Look out for displays with graphics controller and SPI, I2C or 8080/6800 interface.
Oliver
Thanks, Oliver. You saved my time.
