First of all, is it possible to connect 2 Uno boards for simple command transmission between them without using the same wire? (In fact I only got 2 wires to do that and I need both way comms)
Secondly, if it's posible, how to do that?
I've tried using this (220ohm resistor, both boards are connected to separate power sources), but it provides mostly noise on digitalOutput() -> digitalInput().
I am quite noobish in electronics, so I don't really get the logic behind it.
Okay, so it means arduino pin set to input mode doesn't provide closed circuit?
Edit: Anyway, thanks. It just poped to my head that I just need to take a look at arduino schematic to understand how pins work.
Never connect 2 output pins together without at least a 220 Ohm resistor between, if one is HIGH and the other LOW you might destroy one or both. Google "1 wire communications".
