Hi !
I recently started working with arduino. Actually I was was trying to connect 3 PIR and 3 led's connected with them individually. Vcc and ground is common for all PIR's , even that ground is connecting led's as well. But anode of leds and data pin of PIR's are connected with arduino from from pin d8 to d13. But when I trying to uploade the sketch , after uploading sketch only one PIR is responsive. So I think arduino is not able to drive all three PIR's. But not sure. So do I need to add transistors. Help will be appreciated.
