I have a project which has a power supply of 7.4V 10aH. I want to use this power supply to power an arduino nano board, yet I am unsure if the arduino board can take that much power without getting damaged.
What solution is there if this is a problem....
Thanks
If the device operates from 7.4volts then it matters not how many Ah the pack is. A device only consumes the current it requires, providing it is being powered by the correct supply voltage.
jackrae:
Thank you for your answer jackrae. What do you mean powered by the correct supply voltage? Would 7.4 volts be correct supply voltage?
Just connect the +7.4 volts to the Vin of the arduino nano - it's internal regulator will do the rest.
Allan
