Hi as says in the title I am wishing to connect an arduino pro mini 5v to a 42v LED driver and I am hoping I can get some feedback before I do.
My idea is as follows:
LED driver with 60W 42v output
Connected to 50W LED lights (it has an output connector at the end to allow daisy chaining of more lights)
LM2596HV step down converter adjusted to 5v output connected to the output connector of the LED light
Arduino Pro Mini 5v
Will this work? Or are LED driver sensitive to current draw of LM2596HV + Arduino Pro mini?
My intentions are to add a thermistor to the pro mini and measure LED temperature.
Connect the transistor of an opto coupler to Dim(+) and Dim(-) of that LED driver.
Then drive the opto LED ( with CL resistor) from an Arduino PWM pin.
Leo..
yes. I would like to control dimming using the arduino eventually, and use thermistor to measure led temperature and have arduino dim led if temperature is too high.
