Connecting a device to wireless router
Hello,
What components I need for the device can connect to the wireless router? (I want my device will get arguments from the Internet.)
Thank you
Duct tape!
If that doesn’t provide the kind of “connection” that you want, perhaps you could tell us what device you want to connect to the wireless router, what other devices are connected to the router, and whether you want that connection to be wired or wireless.
Thanks for your response,
The device I make will get arguments from the Internet and will run relay. The device must be connected to a wireless network. Other devices connected to the router are desktops and laptops (connected wired and wiresless). No relation to the project. I want to be device LCD screen with a choice to connect to a wireless network(Wizard).
Thanks again
The Roving Networks WiFly RN-XV is a good low-cost option.
Thank you.
When you research a shield to use with it, be careful to find one that has proper 5V to 3.3V level shifting on the data in pin for the module. I've listed a couple here, as well as a couple to avoid: https://github.com/harlequin-tech/WiFlyHQ/wiki.
