What should have been a walk in the park is turning into a rabbit hole with no success.
I have two different GPS modules (Neo-6M, Neo-M8N) and I'm trying to connect one of them to an ESP32 WRover.
The problem I have is that no matter what code or Rx,Tx wiring I'm using, I can't get the GPS to send data to the serial monitor.
The LED on the GPS is blinking slowly (once a sec) and I guess that means that the power to the GPS is correct (I used the 3.3V from the ESP32 board and the board in connected to the computer via USB)
I started with the below code, where I tried changing the Rx,Tx pins several times and also the Baud rate.
I started with this code
#define RXD2 16
#define TXD2 17
#define GPS_BAUD 9600
HardwareSerial gpsSerial(2);
void setup(){
Serial.println("setup started");
gpsSerial.begin(GPS_BAUD, SERIAL_8N1, RXD2, TXD2);
Serial.println("Serial 2 started at 9600 baud rate");
void loop(){
while (gpsSerial.available() > 0){
char gpsData = gpsSerial.read();
Serial.print(gpsData);
Serial.println("-------------------------------");
That's the output I get
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4832
load:0x40078000,len:16460
load:0x40080400,len:4
load:0x40080404,len:3504
entry 0x400805cc
setup started
I also tried using the TinyGPSPlus.h library and its examples, but I can't get passed the part where I need to include <SoftwareSerial.h>, it's probably not part of the ESP32 board libraries and I can't install it manually as well.
that's the code I tried using with the library
#include <TinyGPSPlus.h>
#include <SoftwareSerial.h>
This sample sketch demonstrates the normal use of a TinyGPSPlus (TinyGPSPlus) object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 4800;
// The TinyGPSPlus object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
ss.begin(GPSBaud);
Serial.println(F("DeviceExample.ino"));
Serial.println(F("A simple demonstration of TinyGPSPlus with an attached GPS module"));
Serial.print(F("Testing TinyGPSPlus library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F("by Mikal Hart"));
// This sketch displays information every time a new sentence is correctly encoded.
while (ss.available() > 0)
if (gps.encode(ss.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while(true);
void displayInfo()
Serial.print(F("Location: "));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
Serial.print(F("INVALID"));
Serial.print(F(" Date/Time: "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
Serial.print(F(" "));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
