Connecting a serial port to an Arduino RX pin?
Howdy,
I am planning to make a simple breadboard Arduino that needs to accept incoming serial data. The chip is already programmed with code for this and I am wondering the best way to hook up a serial connector.
Can I just connect to a computer's serial port via GND and RX into the Arduino, or do I need other components for voltage adjustment?
Ta.
You must have a serial line level converter. The Arduino serial is actually TTL serial, not RS232 standard serial. Most people use a MAX232 converter and wire it up, it will do bi-directional communication with the Arduino (bring up the TX pin and bring down the RX pin with that single chip).
If you want to buy a board you can pick up this guy for really cheap: http://www.futurlec.com/Mini_RS232_TTL_5V.shtml WARNING: 10-14 day shipping is the reason they're cheap.
Otherwise Sparkfun has the bare chips: http://www.sparkfun.com/commerce/product_info.php?products_id=316
Thanks for that, I thought so :-)
Ok, I have had a look at the original Arduino Serial board, and that does not use a MAX, it looks like it uses some discreets to do the conversion?
Also I only need one way coms, into the Arduino.
You may be able to get by with just a NPN transistor and two resistors. I've been using the below setup for ~6 years on my pan/tilt web cam.
Sweet,
Cheers dude, and thanks for taking the time to attach the pic.
I have previously just used a resistor to drop the voltage for PIC chips and rs232.
I just ordered some MAX232’s but will try your method.
:slight_smile:
Hey, that's the same CAD system Grumpy_Mike uses!
