Connecting an ethernet shield enc28j60 with arduino to ms sql (offline)
Good day. I hope you can help me with my project. I'm making an offline monitoring system, I am using ms sql and I will use ethernet shield to connect with my laptop which will serve as my server. My problem is I don't know the arduino codes that I have to use because this is my first time using an arduino. Thank you in advance ;D ;D
What research have you done so far?
What options look like they could work?
Sir sorry but what do you mean by asking for options that could work?
You should probably start by learning how to use the Ethernet shield. Look at the examples in the Arduino software.
And what is an offline monitoring system?
It is an offline school base monitoring system, instead of making a web page, we make a GUI for the project. What I can't understand is on how I can transfer the data gathered by my humidity sensor (for example) to my laptop using an ethernet.
ily_926:
Do a Google search for "arduino sql server". All the information you need is on the first page. There are several options.
