Connecting and using an ADS1232
(I’m new to external ADC’s and SPI in general, so please be patient)
I need an external ADC for a school project as the resolution of the internal ADC of the Arduino UNO/Nano/Mega is just too low. So I decided to buy one on Amazon which was already soldered (See attached picture). It arrived yesterday and I realized that I have no clue how to use it. After some googleing I found these posts:
http://forum.arduino.cc/index.php/topic,128823.0.html
I connected (based on the code I found) the following pins to my Arduino Uno:
Gain0/1 5V
REFP 5V
SPEED 5V
TEMP GND
A0 GND
CLKIN GND
DOUT D12
CLK D13
PDWN D9
The code:
#include <SPI.h>
#define MISOPIN 12
#define SCLKPIN 13
#define PDWN 9
#define A0 5
//MUX Pin Settings
//    A0    |    A1    |    Inputs
// Low  (0) | Low  (0) | AINP1 11 AINN1 12
// Low  (0) | High (1) | AINP2 18 AINN2 17
// High (1) | Low  (0) | AINP3 13 AINN3 14
// High (1) | High (1) | AINP4 16 AINN4 15
uint32_t data[3];
long val = 0;
// declare 3 bytes = 24 bits
 pinMode(SCLKPIN, OUTPUT); pinMode(MISOPIN, INPUT); pinMode(PDWN, OUTPUT);
 // corresponding to SCK pin and DRDY/DOUT pin on ADC
 digitalWrite(PDWN, HIGH);
 digitalWrite(A0,LOW);
 reset_adc();
 // put ADC on reset at the outset
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE1);
 // initialize SPI (with default settings, including...
 // CPOL = 0: so that SCLK is normally LOW
 // CPHA = 0: data sampled on rising edge (LOW to HIGH)
 // perhaps try changing CPHA ??
 digitalWrite(SCLKPIN, LOW);
 // release ADC from reset; now we're at a known point
 // in the timing diagram, and just have to wait for
 // the beginning of a conversion cycle
 if (digitalRead(MISOPIN) == LOW) read_adc();
 // "sort of" an interrupt to go to read_adc routine;
 // can use hardware interrupt in future but now just poll
 delay(100);
void reset_adc()
// to reset ADC, we need SCLK HIGH for min of 4 CONVCYCLES
// so here, hold SCLK HIGH for 5 CONVCYCLEs = 1440 usec
 digitalWrite(SCLKPIN, HIGH);
 delayMicroseconds(1440);
void read_adc()
 drdy_wait();
 // go to drdy_wait routine, where we wait for
 // DRDY phase to pass, and thus for DOUT phase to begin
 data[0] = SPI.transfer(0x00);
 data[1] = SPI.transfer(0x00);
 data[2] = SPI.transfer(0x00);
 // read in adc data (sending out don't care bytes)
 // and store read data into three bytes */
if (data[2] & 0x80)
    val = 0xff;
val = (val << 8) | data[2];
val = (val << 8) | data[1];
val = (val << 8) | data[0];
 Serial.println(val);
 // print out data;
 // will these instructions eat into time significantly?
 // possible improvement: store all data from multiple cycles
 // into array, and print out only later at end.
void drdy_wait()
// wait for DRDY to pass and to reach start-point of DOUT
 delayMicroseconds(30);
 // to be safe, 30 usec, instead of 27 usec, which is
 // the expected period of DRDY phase
(based on: https://e2e.ti.com/support/data-converters/f/73/t/560004?Help-with-setting-up-an-ADS1234-with-4-load-cells-to-an-Arduino-Uno-or-a-Raspberry-Pi-3)
As said in the Datasheet, I can connect the AINN1 pin to ground to measure an unipolar signal on AINP1.
I’m not quite sure what a differential Signal is, so this was the best I can do.
I thought, if I connect AINN1 and AINP1 to Grund (or AINN1 - Gnd & AINP - 5V), I should get a constant number as result.
But thats not the case. I get random numbers starting at around -825242
and ending at ~1713729126.
Somebody knows why?
