connecting arduino mkr 1000 to thinger.io
Can anyone tell me what I am doing wrong with this program? Any advice will be helpful thank you.
#include <WiFi101.h> //Thinger
#include <ThingerWifi101.h> //Thinger
#include <Wire.h> //Accelerometer
#include <Adafruit_Sensor.h> //Accelerometer
#include <Adafruit_ADXL345_U.h> //Accelerometer
#define USERNAME “”
#define DEVICE_ID “”
#define DEVICE_CREDENTIAL “”
#define SSID “”
#define SSID_PASSWORD “”
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345); //Accelerometer
int x = 0; //Reset to 0
int y = 0;
int z = 0;
//FSR sensors/
#define noFSRs 3 // Number of FSRs connected
#define FSR1 A1 //Analogue ports
#define FSR2 A2
#define FSR3 A3
float fsrVoltageArray[3]; // The analog reading converted and //scaled to voltage as a floating point //number
float fsrForceArray[3]; // The force in Newton
float fsrWeightInGramsArray[3]; // Weight converted to grams
int pinArray[3] = {FSR1, FSR2, FSR3}; // The pin ID for the //three devices
float forceMaxArray[3] = {100.0, 100.0, 100.0}; // Maximum forces //supported
float million = 1000000.0; // Unit for "1/micro
float conversionToKgrams = 1.0 / 9.80665;
long K = 1000;
long R = 10*K; // R in K Ohm
long Vcc = 5000; // 5V=5000mV, 3.3V = 3300 mV
float voltageMax = 0.98 * Vcc; // Maximum voltage set to 95% of Vcc. Set //the force to the maximum beyond this //value.
ThingerWifi101 thing(USERNAME, DEVICE_ID, DEVICE_CREDENTIAL);
//Call to set up WiFi function
void setup(void) {
thing.add_wifi(SSID, SSID_PASSWORD);
if (!accel.begin()) { //Initialise the sensor
Serial.println(“No ADXL345 detected.”);
accel.setRange(ADXL345_RANGE_16_G); //Range for this sensor
thing[“accelerometer”] >> (pson & out) {
sensors_event_t event;
accel.getEvent(&event);
out[“x”] = event.acceleration.x;
out[“y”] = event.acceleration.y;
out[“z”] = event.acceleration.z;
/FSR sensors/
thing[“pressure”] >> (pson & out) {
out[“FSR1”] = analogRead(FSR1);
// Serial.print(“FSR1:”);
// Serial.println(analogRead(FSR1));
out[“FSR2”] = analogRead(FSR2);
// Serial.print(“FSR2:”);
// Serial.println(analogRead(FSR2));
out[“FSR3”] = analogRead(FSR3);
// Serial.print(“FSR3:”);
// Serial.println(analogRead(FSR3));
thing[“voltage”] >> (pson & out) {
for (int FSR = 0; FSR < noFSRs; FSR++) {
fsrVoltageArray[FSR] = 0.0; //Reset values upon entry
fsrForceArray[FSR] = 0.0;
int fsrPin = pinArray[FSR];
int fsrReading = analogRead(fsrPin);
fsrVoltageArray[FSR] = (float) map(fsrReading, 0, 1023, 0, 5000);
} //End of loop over FSR’s
out[“FSR1voltage”] = fsrVoltageArray[0];
out[“FSR2voltage”] = fsrVoltageArray[1];
out[“FSR3voltage”] = fsrVoltageArray[2];
thing[“newton”] >> (pson & out) {
// The value of the force F as a function of the voltage V is ///computed as: F(V) = (Fmax/Vmax) * V
float force_value = (forceMaxArray[FSR] / voltageMax) * fsrVoltageArray[FSR];
// Three situations are distinguished:
// 1. If V is too close to the maximum (as defined by voltageMax // ), the force can
// go to infinity. This is avoided by setting it the maximum //value as soon as it is higher than our threshold voltageMax.
// 2. If the computed force F is too small, we set it to zero to // avoid noise effects.
// 3. In all other cases, we take the logarithmic value to
//reduce the sloop and better distinguish small changes.
if ( fsrVoltageArray[FSR] < voltageMax ) {
// V is not too high in this branch
if ( force_value <= 1.00 ) {
fsrForceArray[FSR] = 0.0; // Force is too small, set it to // zero
fsrForceArray[FSR] = log10(force_value); // Value is okay, //take the log of //this
// Cap the force if the voltage is too close to Vcc (for Vcc //it would be infinity)
fsrForceArray[FSR] = log10(forceMaxArray[FSR]);
Serial.print("Cut off activated for FSR = "); Serial.println(FSR);
} // End of loop over FSRs
out[“FSR1newton”] = fsrForceArray[0];
out[“FSR2newton”] = fsrForceArray[1];
out[“FSR3newton”] = fsrForceArray[2];
}; //End of thing
thing[“weight”] >> (pson & out) {
//Straightforward computation to convert the force in Newton to the weight in grams
fsrWeightInGramsArray[FSR] = fsrForceArray[FSR] * conversionToKgrams * 1000.0;
out[“FSR1weight”] = fsrWeightInGramsArray[0];
out[“FSR2weight”] = fsrWeightInGramsArray[1];
out[“FSR3weight”] = fsrWeightInGramsArray[2];
}; //End of thing
} //End of setup
void loop(void) {
thing.handle();
Yes.
You forgot to use code tags when posting your code.
You forgot to tell us what the code actually does.
You forgot to tell us what you expect the code to do.
