So I’m starting a new project here where I need to use a MKR GSM 1400 board and connect it to a GPS module from adafruit. I am having a little bit of trouble connecting both of them because the MKR GSM does not recognize SoftwareSerial library which is needed for the GPS module.
However, the SoftwareSerial library can be recognize when I use Arduino/Genuino Uno board. Does anyone have any tips for me where I can use the SoftwareSerial library so that the GPS module can work with MKR GSM board?
So if you are using the Arduino MKR GSM 1400 board, this type of code where I want to declare which pin will be used for the TX and RX of the Adafruit Ultimate GPS;
SoftwareSerial mySerial(8, 7);
is not working, even when I include the library:
#include <SoftwareSerial.h>
is also not working.
In my opinion, the board itself doesn’t recognize the library and can only be recognized by using Arduino/Genuino Uno board.
As the MKR1400 uses the SAMD processor, which can be configured for multiple hardware serial inputs, maybe they did not bother to port the softwareserial across.
Details of serial port support on the getting started page;
The SAMD21 has 6 sercom interfaces so technically, you can have a total of six hardware serial ports. There's no need to emulate a serial port if you have six available.
