Hi all!
Im hoping for some advice on what i suspect (hope!) is a relatively straightforward task. Im new to arduino so im very much learning still.
Basically I have a Motorsport Electronics Me221 ECU which i would like to connect an arduino to, in order to extract data from it.
The ECU has a 9pin connector and uses r232 communication. To connect the ECU to my laptop, i have a Serial-to-USB adapter cable and I can then use the ME tuning sw.
So would i simply need to attach a female usb port to the arduino, and terminate this port to the appropriate serial pins on the board so I can connect the USB to serial lead?
Or is there something else I need to buy or use to achieve the above?
Thanks in advance for your help and support!
Kind Regards
Joe
