hi, i have a question, there is a way other than the arduino wifi shield to conect arduino uno to wifi?? thanks.
Yes, you can use an Ethernet shield and plug that into a WiFi repeater
You will probably find this cheaper than a WiFi shield even if you don't already have the Ethernet shield. WiFi shields are not without their problems. This method avoids all of them. I did it because it was the bleeding obvious but I believe it is now becoming the norm.
Or you could use the wireless/SD shield and a WiFly unit or an XBEE shield and a Wifly (Wifly and xbee have the same pinout.)
The Wifly option is cheaper (just) and simpler and only usethe tx/rx pins which you arn't going to be using for serial.
google WiflY.
Mark
