Connecting Arduino Wirelessly to PC
Hey all,
I have crafted a LED matrix table using an Arduino Uno and Glediator.
I have to run a long USB cable to my computer to get it running.
So I was wondering, is there a way to wirelessly connect it to my computer, while still being able to use glediator?
*I don't know anything about coding
Thanks.
Bluetooth? Since you are currently connected by USB, no change of code is required.
Hey,
How can I use a bluetooth module?
I need to select the USB COM port in the program
It will still appear there as it was connected by cable?
Ron27:
Won't you have disconnected the cable?
In any case the PC's bluetooth device will use a different COM port.
...R
I was asking if the bluetooth device will appear as a COM Port like when it's connected by a USB cable.
Anyways, which bluetooth module do you recommend? I prefer something cheap and reliable.
Ron27:
I wonder if you are a bit confused.
The bluetooth module inside your PC is what appears to the PC as the COM port. And, yes, as far as a program on the PC is concerned it should be identical to a COM port over a USB cable.
The Arduino knows nothing about COM ports - it just sees a serial connection and it has no idea whether there is a PC or another Arduno at the other end.
I have not heard anyone complain about the quality of Arduino bluetooth modules. The HCO5 is commonly used but the HC06 is sufficient and is a little cheaper. However you should be aware that any Bluetooth link needs a master and a slave and the HCO6 can only act as a slave whereas the HCO5 can be either master or slave. For communication with a PC the PC will be the master.
...R
Thank you for clearing that up.
So from what I understand, I will have the purchase two bluetooth modules?
If so, how do I connect the HC-05 to my computer, and how do I set them to be master/slave?
Ron27:
You will only need to buy two modules if your PC is not already equipped with Bluetooth - I thought most of them have it as standard. Certainly most laptops do.
And if you need to get a bluetooth module for your PC it will have to be a USB Bluetooth module which is quite different from the modules that connect to an Arduino.
...R
Oh, I do have bluetooth in my computer.
After I connect the module to Arduino and pair it with my PC, it will just appear as one of the COM Ports?
I found this diagram for wiring it up, is it correct? :
It is good practice to wire Arduino Tx through a 1k/2k voltage divider. It is not usually fatal if you don't.
You might find the following background notes useful
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
Ron27:
Yes.
...R
