Connecting Arduino with Philips Hue
I’m trying to control Philips Hue lights through an Arduino Uno (with a WiFi shield). Both the shield and the Philips Hue Bridge are connected to the same network and I’m trying to send JSON commands from the Arduino to the Hue Bridge from the following code taken from here.
#include <SPI.h>
#include <WiFi.h>
#include <WiFiClient.h>
char ssid[] = "mynetwork";     //  your network SSID (name)
char pass[] = "mypass";  // your network password
int status = WL_IDLE_STATUS;     // the Wifi radio's status
//Hue constants
const char hueHubIP[] = "192.168.0.50";  //Hue Bridge IP
const char hueUsername[] = "myhue";  //Hue username
const int hueHubPort = 80;
IPAddress server(192,168,0,50);
WiFiClient client;
//Hue variables
boolean hueOn;  // on/off
int hueBri;  // brightness value
long hueHue;  // hue value
String hueCmd;  // Hue command
unsigned long buffer=0;  //buffer for received data storage
unsigned long addr;
IPAddress ip;
 //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while (true);
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the data:
  Serial.print("You're connected to the network");
  printCurrentNet();
  printWifiData();
  ip = WiFi.localIP();
  Serial.println(ip);
    String command = "{\"on\": true,\"hue\": 50100,\"sat\":255,\"bri\":255,\"transitiontime\":"+String(random(15,25))+"}";
    setHue(1,command);
    command = "{\"on\": true,\"hue\": 65280,\"sat\":255,\"bri\":255,\"transitiontime\":"+String(random(15,25))+"}";
    setHue(2,command);
    command = "{\"hue\": 65280,\"sat\":255,\"bri\":255,\"transitiontime\":"+String(random(15,25))+"}";
    setHue(1,command);
    command = "{\"hue\": 50100,\"sat\":255,\"bri\":255,\"transitiontime\":"+String(random(15,25))+"}";
    setHue(2,command);
/* setHue() is our main command function, which needs to be passed a light number and a
 * properly formatted command string in JSON format (basically a Javascript style array of variables
 * and values. It then makes a simple HTTP PUT request to the Bridge at the IP specified at the start.
boolean setHue(int lightNum,String command)
  if (client.connect(server, 80))
    Serial.println(F("connected to server"));
    while (client.connected()&& status == WL_CONNECTED)
      client.print(F("PUT /api/"));
      client.print(hueUsername);
      client.print(F("/lights/"));
      client.print(lightNum);  // hueLight zero based, add 1
      client.println(F("/state HTTP/1.1"));
      client.println(F("keep-alive"));
      client.print(F("Host: "));
      client.println(hueHubIP);
      client.print(F("Content-Length: "));
      client.println(command.length());
      client.println(F("Content-Type: text/plain;charset=UTF-8"));
      client.println();  // blank line before body
      client.println(command);  // Hue command
    client.stop();
    return true;  // command executed
    return false;  // command failed
  //client.flush();
  //client.stop();
/* A helper function in case your logic depends on the current state of the light.
 * This sets a number of global variables which you can check to find out if a light is currently on or not
 * and the hue etc. Not needed just to send out commands
boolean getHue(int lightNum)
    client.print(F("GET /api/"));
    client.println(F(" HTTP/1.1"));
    client.println(F("Content-type: application/json"));
    client.println();
      if (client.available())
        client.findUntil("\"on\":", "\0");
        hueOn = (client.readStringUntil(',') == "true");  // if light is on, set variable to true
        client.findUntil("\"bri\":", "\0");
        hueBri = client.readStringUntil(',').toInt();  // set variable to brightness value
        client.findUntil("\"hue\":", "\0");
        hueHue = client.readStringUntil(',').toInt();  // set variable to hue value
        break;  // not capturing other light attributes yet
    client.stop();
    return true;  // captured on,bri,hue
    return false;  // error reading on,bri,hue
void printWifiData() {
  //WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  void printCurrentNet() {
  //SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
The above code gets my Arduino connected to mynetwork and I have also connected Hue Bridge to the same but it throws an error of No Socket Available (see attachment).
