Connecting Atmel ICE to MKR board - multiple grounds
I’m making a cable to connect my Atmel ICE to my MKR GSM1400. The Atmel ICE has a 10 pin IDC connecter; The pin mapping is below as per the datasheet:
Name AVR port pin SAM port pin Description
SWDC 1 4 Serial Wire Debug Clock. LK
SWDIO 5 2 Serial Wire Debug Data Input/Output.
SWO 3 6 Serial Wire Output (optional- not implemented on all devices).
nSRST 6 10 Reset.
VTG 4 1 Target voltage reference.
GND 2, 10 3, 5, 9 Ground.
The table doesn’t specify whether to connect all three grounds for a SAM SWD target, whereas it explicitly specifies to do so for a SAM JTAG target.
Why would there be multiple grounds and does an SWD target require all of them or just one?
There are not multiple grounds, there is 1 ground* with 2 or 3 connections to it. As long as a ground on one device is connected to a ground on the other it should be OK.
*If you doubt this go outside and look around, how many grounds do you see?
