I have purchased Arduino Zero MKR board instead of Zero, as it was not available in stock (seems Arduino is not making it any more). I was interested in using the Arduino Pro feature of the pro IDE. So I purchased Atmel ICE debugger. Arduino MKR Zero has debug pin. When I am connecting it to the debugger and debugging the board in Arduino pro IDE, it is not uploading the data nor going into debug mode.
Arduino Zero has inbuild Atmel debugger. Arduino Zero MKR can be connected with debugger and it should work in Arduino Pro IDE (this was my initial premises). Let me know if I am wrong or any extra information is needed.
In Atmel ICE debugger - center red light was constant on.
Error msg:
Open On-Chip Debugg0er 0.10.0+dev-gf0767a31 (2018-06-11-13:36)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
debug_level: 0
none separate
adapter speed: 400 kHz
cortex_m reset_config sysresetreq
in procedure 'program'
in procedure 'init' called at file "embedded:startup.tcl", line 496
in procedure 'ocd_bouncer'
** OpenOCD init failed **
shutdown command invoked
Upload error: Error: 2 UNKNOWN: uploading error: uploading error: exit status 1
