connecting ATTiny to a Nano using I2C - can't send values > 127
Hello you all...
For a course excercise I'm trying to run an example project of a counter running on an ATTiny and after transmitting the vaue to the Nano to show it on its serial monitor.
I adapted the code of https://www.arduino.cc/en/Tutorial/MasterWriter with TinyWire but somehow the counter stops at value 127.
There's probably a fairly simple reason. I just can't figure out why...
I someone would be so kind to explain me why I would be so grateful :slight_smile:
That code is just to bad to be used in a tutorial.
receiveEvent is called in interrupt context. As there interrupts are disabled you must not call any writing method of the Serial object as it depends on interrupts working to do it's stuff.
Additionally the master reads the data from the slave into a variable of type char which is a signed 8bit value. So if the sent value is turning from 127 to 128 it will change on the master from 127 to -127.
Slave codes should be like this following @pylon post#1:
#include <Wire.h>
volatile bool flag1 = false;
  Wire.begin(8);                // join i2c bus with address #8
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
   if(flqg1 == true)
       byte x = Wire.read();
       Serial.println(x);  //will print all received values as 0, 1, 2, ...., 127, ..., 255
       flag1 = false;
   //delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
    flag1 = true;
    //char c = Wire.read(); // receive byte as a character
    //Serial.print(c);         // print the character
 // int x = Wire.read();    // receive byte as an integer
 // Serial.println(x);         // print the integer
The Wire.read() can (and probably should) be executed in the interrupt routine but the rest (especially the serial output must be done in loop).
pylon:
As people are saying that the interrupt context should be as short as possible, I have done the Wire.read() operation in the loop function. Apart from that I agree with you.
Thanks a lot for the input - I adapted the code but still the counter stops at 127 - seems that I'm missing something very basic here but I just don't get why it's doing what's it doing...
Code on the ATTiny:
#include <twi.h>
#include <TinyWire.h>
pinMode(3, OUTPUT);
TinyWire.begin(); // join i2c bus (address optional for master)
uint8_t x = 0;
TinyWire.beginTransmission(8 ); // transmit to device #8
TinyWire.write(x); // sends one byte
TinyWire.endTransmission(); // stop transmitting
digitalWrite(3, HIGH);
x++;
Code on the Nano:
#include <Wire.h>
uint8_t x;
bool flag;
Wire.begin(8 ); // join i2c bus with address #8
if (flag) {
Serial.println(x, DEC);
flag = false;
void receiveEvent(int howMany) {
x = Wire.read();
flag = true;
What does "stops at 127" means? Does it freeze there? Does it start over after 127 with a value of 0?
