connecting bluetooth CH-06 to uno arduino
my project is connecting bluetooth CH-06 to uno arduino and send msg to mobile when the analog input reach the threshold. But i got some errors, I hope anyone can help please.
thanks
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
float A = A0;
float B = A1;
float C = A2;
float D = A3;
float thresh = 614;
float XA = 0;
float XB = 0;
float XC = 0;
float XD = 0;
pinMode(A,INPUT);
pinMode(B,INPUT);
pinMode(C,INPUT);
pinMode(D,INPUT);
Serial.begin(9600); //open serial port, sets data rate to 38400 bps
mySerial.begin(9600); //the value of baud rate is 9600 , default
delay(200);
XA = analogRead(A);
XB = analogRead(B);
XC = analogRead(C);
XD = analogRead(D);
if (XA >= thresh || XB >= thresh || XC >= thresh || XD >= thresh)
delay(100);
mySerial.print("Situation is Dangerous");
delay(100);
mySerial.print("Situation is GOOD");
delay(100);}
Serial.write(XA);
delay(100);
Serial.write(XB);
delay(100);
Serial.write(XC);
delay(100);
Serial.write(XD);
delay(200);
(deleted)
float A = A0;
float B = A1;
float C = A2;
float D = A3;
I've heard of floating pins.
Does this help at all?
DO NOT CROSS-POST, CROSS-POSTING WASTES TIME.
my project is reading 4 analog signal input and once any of the input reach threshold, the uno arduino will send msg through the Bluetooth to android device. I have some errors i didn't get them so please if anyone can help I will be thankful...
my code
float A = A0;
float B = A1;
float C = A2;
float D = A3;
float thresh = 614;
float XA = 0;
float XB = 0;
float XC = 0;
float XD = 0;
pinMode(A,INPUT);
pinMode(B,INPUT);
pinMode(C,INPUT);
pinMode(D,INPUT);
delay(200);
XA = analogRead(A);
XB = analogRead(B);
XC = analogRead(C);
XD = analogRead(D);
delay(100);
delay(100);
delay(100);}
Serial.write(XA);
delay(100);
Serial.write(XB);
delay(100);
Serial.write(XC);
delay(100);
Serial.write(XD);
delay(200);
gdp_tweel.ino (974 Bytes)
There are two } after
Serial.print ("Situation is good");
delay(100);
Remove one
Check where the loop() function ends in your program.
HINT - it is not at the end of the code that you have posted.
Auto format may help you see the problem.
And neither did we (hint for next time)
And which part of "DO NOT CROSS-POST" didn't you understand?
Duplicates deleted.
