Connecting Bluetooth gamepad to Arduino Uno?
I'm trying to figure out how to connect a Bluetooth gamepad to my Arduino Uno. I have the Uno, a power supply, and an HC-05 Bluetooth Module.
The end goal here is to use the gamepad to set a servo to max, minimum, and have a forward and backward rocker.
I have been unable to find a tutorial which connects the HC-05 module to a gamepad, but I have found plenty that connect to Android phones. (I don't want to do that.)
I'm new to Arduino, and I'm beginning to think that I ordered the wrong module.
Is this possible with my hardware? If not, what alternative hardware can I use to accomplish this?
Furthermore, I would appreciate it if someone could point me in the right direction to figuring out the process of connectingetting, pairing and coding for this project.
Thanks in advance!
Try to find a HC-05 example, that lists all reachable devices. Then find your gamepad in that list, and use the parameters shown for it, to establish a connection.
It's not possible. Your gamepad model is not supported. Should've got the other one that is.
INTP:
It's not possible with any gamepad and the HC-05? I never provided a gamepad model.
Guess that was my point. Maybe a third reply will contain that info?
An interface between the BT and the gamepad will likely be required - something that gathers the gamepad info and then processes that into a data stream.
The gamepad is very likely Bluetooth HID. The HC-05 will be Bluetooth V2.1 and not compatible with the gamepad.
This is something I looked at a short while ago. There is quite a lot of information on line about turning an Arduino in to an HID but very little on connecting an Arduino to a HID.
