I am trying to connect my board, which has a atmega168 and bluetooth RN-41 on board, with the windows hyperterminal. The baud rate is 112500 with no parity,8 data bits and 1 stop bit.All the settings are correct but I get gibberish on the terminal. Can anybody suggest what I should do to get correct dataAlso I am not sure if the fuses that I set are correct.
Extended_fuse - 0xF8 High_fuse - 0xDA Low_fuse - 0xFF
unlock_bits - 0x3F lock_bits - 0xCF
Any insight into this issue would be great.
Thanks SK
