Any one let you know if my code was correct plz
#include
// Define RS485 control pins
#define MAX485_DE 3
#define MAX485_RE_NEG 2
// Create ModbusMaster instance
ModbusMaster node;
// Function for enabling transmission mode
void preTransmission() {
digitalWrite(MAX485_RE_NEG, 1);
digitalWrite(MAX485_DE, 1);
// Function for enabling reception mode
void postTransmission() {
digitalWrite(MAX485_RE_NEG, 0);
digitalWrite(MAX485_DE, 0);
// Initialize control pins for RS485
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
// Set initial mode to receive
// Initialize serial communication for Modbus
Serial.begin(9600); // Use your selected baud rate
Serial1.begin(9600, SERIAL_8E1); // Baud rate, Even parity, 1 stop bit
// Start Modbus communication with Slave ID 1
node.begin(1, Serial1);
// Set transmission and reception callback functions
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
uint8_t result;
float value;
uint32_t longValue;
// Array of register start addresses as per the communication map
uint16_t startAddress[] = {40101, 40103, 40105, 40107, 40109, 40111, 40113, 40115, 40117, 40119,
40121, 40123, 40125, 40127, 40129, 40131, 40133, 40135, 40137, 40139,
40141, 40143, 40145, 40147, 40149, 40151, 40153, 40155, 40157, 40159, 40217};
int numParameters = sizeof(startAddress) / sizeof(startAddress[0]);
for (int i = 0; i < numParameters; i++) {
if (i < 30) { // For float values (read 2 registers)
result = node.readHoldingRegisters(startAddress[i] - 40001, 2);
if (result == node.ku8MBSuccess) {
uint32_t rawData = ((uint32_t)node.getResponseBuffer(0) << 16) | node.getResponseBuffer(1);
memcpy(&value, &rawData, sizeof(value)); // Convert raw data to float
Serial.print("Parameter ");
Serial.print(i + 1);
Serial.print(": ");
Serial.println(value, 4); // Print float value with 4 decimal places
Serial.print("Read Error at parameter ");
Serial.print(", Error Code: ");
Serial.println(result);
} else { // For Unsigned long value (Load Hours Received)
longValue = ((uint32_t)node.getResponseBuffer(0) << 16) | node.getResponseBuffer(1);
Serial.print("Load Hours Received: ");
Serial.println(longValue);
Serial.print("Read Error at Load Hours Received, Error Code: ");
delay(500); // Delay between reading each parameter
delay(5000); // Delay before the next loop
I can try to get data from LG+5310 using Arduino
